11 Replies Latest reply on Jun 6, 2017 6:31 PM by sargums46564804
    How call multiple pdf's
    sargums46564804 Level 1
      I have a variable called ODoc which is the current pdf and calls a global function which places a label on it based on input into a dialogue (code not shown):
      var oDoc = event.target;
              global.DoPlaceDocNumbers(oDoc)
      However, I would like it to call all the pdf's in the batch so the labels can be applied all at the same time.
      I have posted this question before and received an answer about calling all the pdf's at once and then performing the action.  I have been researching this to see if there is an "event.all" (or something similar) which I did not see and then tried using a for loop to accomplish this but have not been successful:
      for (var i=0; i<oDoc; i++)
        • 1. Re: How call multiple pdf's
          Bernd Alheit Adobe Community Professional & MVP
          Want you place the labels on all open documents?
          • 2. Re: How call multiple pdf's
            All the documents would not be open.  They would have been selected as a part of the batch record selection of the action wizard. Only the 1st document would be opened to initiate the action wizard.
            Selection of Documents:
            Action Wizard Steps:
            • 3. Re: How call multiple pdf's
              In the Action Wizard you can use:
              global.DoPlaceDocNumbers(this),
              • 4. Re: How call multiple pdf's
                I tried it but it did not work.  It just labels the open document.  Any other ideas?
                • 5. Re: How call multiple pdf's
                  No, I know nothing about your function.
                  • 6. Re: How call multiple pdf's
                    I think a simpler way of asking this is how do I collect all docs (e.g., pdf1, pdf2, pdf2, etc.) and save them as global variables? Can you show me a simple example? Right now, the javascript only runs on event.target (or current document).
                    • 7. Re: How call multiple pdf's
                      We shouldn't need to guess what you are doing to answer your question!
                      When you do an action, a piece of script is run for each file separately. You want to run a dialog once? Run it the first time and set a global flag (but expect to have to quit Acrobat to clear the global flag).
                      • 8. Re: How call multiple pdf's
                        By the way, I guess you might be refusing to include your script either because it is sensitive - this is wise - or because it is large - this is good because we won't read a big script.
                        The solution is to make a very, very short similar script which has the same sort of effect and issues and show us that.
                        • 9. Re: How call multiple pdf's
                          In one action you can collect the docs in a global array. In a other action you can use this array.
                          • 10. Re: How call multiple pdf's
                            Per the suggestion, here is a stripped down version of the script where I tried to make it still execute the labeling function even when the dialogue is not evoked again (see blue txt).  Why?  B/c I don't want the user to have to click the "ok" button for each pdf to apply the label.  I just want the user to click "ok" once and then it labels all the pdf's (pdf 1, pdf 2, pdf 3, etc.) which were selected in the action.
                            //Function DocNumActionDlg
                              var DoNumActionDlg = app.trustedFunction(function()      //Opens dialogue where "ok" button to apply label exists
                               app.beginPriv();
                               return app.execDialog(global.DocNumAction);
                               app.endPriv();
                            //Function DoPlaceDocNumbers (labels Label Content, doc num, and pages numbers for each document)
                               global.DoPlaceDocNumbers = app.trustedFunction(function(oOrigDoc)
                            .// Setup
                                var oDoc = event.target;               //current pdf document (SCS)
                                var cRtn = DoNumActionDlg();      //Dialogue with"ok" button to apply labels.
                                 if ("ok" == cRtn)                            //if user clicks "ok" initiates DoPlaceDocNumbers funtion (above) on current pdf
                                     //Setup Initial Doc Number
                                      if(global.DocNumAction.bIncludePageNum)
                                        global.DoPlaceDocNumbers(oDoc);
                                     //Increment Doc Number if applicable so can get ready for next pdf document as loops again
                                      if(global.DocNumAction.bIncludeDocNum)
                                       global.DocNumAction.nCurrentDocNum++;
                                  else if "ok" != cRtn)  //Here is where i need help b/c this statement does not work. If code sees no dialogue (which I did on purpose), I still want it to label subsequent pdf's.
                            • 11. Re: How call multiple pdf's
                              figured this out.  I have to call the action on the hidden files and then it bypasses the dialogue:
                              if (this.hidden)
                                global.DoPlaceDocNumbers(this);
                                      global.DocNumAction.strInitDocNum = global.DocNumAction.nCurrentDocNum.toString();
                              else
                                  // Setup
                                  {var oDoc = event.target; //current pdf document (SCS)
