18 Replies Latest reply on May 30, 2017 11:31 PM by Cleo_helm
    Adding parts of a Excel file into an InDesign text frame
    Cleo_helm Level 1
      Hello,
      I'm new to JavaScript in InDesign and try to code some things to understand it. I use CS6 (Version 8.0).
      I can place an Text or Excel file into an InDesign document, that is not an issue. But now I want to place single cells of an Excel table into the InDesign document in separate text frames.
      First one question: function xy() means that JavaScript should run this function (the paranthese) and in the curly brackets say how to do the function: function xy(){}, correct?!
      At the moment the result is just my Title Textframe on top and the whole Excel table.
      How can define in the place method that I want a specific part of my EXCEL file only?
      my Code:
          //Define the file I want to use
      var myList = new File("H:/test-excel.xlsx");
         //If NOT the indicated Excel-file exist do the following
      if(!myList.exists) {
                 alert("Save the Excel file");
        //If the indicated Excel-file exist do the following stuff in the else{}
        else {
                  //open a new document
               var myDocument = app.documents.add();
                      //use this current page
              var myPage = myDocument.pages.item(0);
                       //Now we tell the script which measurement units we take, in this case points (pt)
              myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
              myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
                      //defines the Title text frame including content and style
               var myTextFrameTitle = myDocument.textFrames.add();
                      //defines the size of the text frame [y1, x1, y2, x2], which give the coordinates of the top-left and bottom-right corners of the textframe
                      myTextFrameTitle.geometricBounds = [36,36,55,300];
                               //what to write in the field
                      myTextFrameTitle.contents = "Titel";
                              //which font and size
                      myTextFrameTitle.paragraphs.firstItem().appliedFont = app.fonts.item("Arial");
                      myTextFrameTitle.paragraphs.firstItem().fontStyle = "Bold";
                      myTextFrameTitle.paragraphs.firstItem().pointSize= 16;
                      myTextFrameTitle.paragraphs.firstItem().justification = Justification.LEFT_ALIGN
                      //adds the text of only the first Excel sheet to the document below the Title text frame
              var myExcelRowA = myDocument.textFrames.add();
                           //here are all Excel frames which are upcoming defined
                     myExcelRowA.geometricBounds =[65, 36, 90, 68];
                             //place the Excel file into the text field
                     myExcelRowA.place(myList, undefined, false, true)[0];
      I know that I define my Excel file like this, but I don't get this two together:
      //starts a function (named "myImport") to import specific parts of an Excel file
              function myImport(){
                           //says how the Excel file should be imported
                          with (app.excelImportPreferences) {
                                   alignmentStyle = [AlignmentStyleOptions.SPREADSHEET][0];
                                   sheetIndex = 1;
                                   sheetName = "Institute"; //name of the sheet
                                   rangeName = "A1:B2"; //from first to last cell
                                   showHiddenCells = false; //doesn't show hidden cells, write true to also show hidden cells
                                   tableFormatting = TableFormattingOptions.Excel_Formatted_Table;
                                   //viewName = "H:/2017_05_01_HMGU-Struktur_verbesserungen/scripts/test-excel.xlsx";
                                   //myExcel content will appear on the page which is taken form the Excel document
                                  } //closing of with
                } //closing of function
