• Global community
    • Language:
      • Deutsch
      • English
      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Exit
Locked
0
Is there an alternative in using slide show inside tabbed panels?
New Here ,
May 23, 2017 May 23, 2017
I'm building my portfolio online and i was hoping to put a slide show in tabbed panels but there was a warning that it might misbehave. As  my question above, is there an alternative to this short of splitting out all the tab contents into individual child pages?
Many thanks in advance.
Views
178
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Why should it misbehave? What warning are you talking about?
The only disadvantage for now is, that slideshows aren't responsive in actual Muse. But this is true for slide shows outside of panels and composition as well.
Votes
Translate
Translate
Report
Report
New Here ,
Thank you for replying GĆ¼nter. Image of the warning attached.
Votes
Translate
Translate
Report
Report
If you can create a small new .muse file with just the error causing slideshow and share it with us via Dropbox or WeTransfer, it will be very helpful for us to troubleshoot the issue.
Regards,
Ankush
Votes
Translate
Translate
Report
Report
LEGEND ,
It should be obvious, that a light box within a light box canā€™t work! Normally, such a construction is useless. But I think, this isnā€™t your issue. Nevertheless: At this point we should know exactly what you are doing.
You told us, you have a slide show within a tabbed panel. If you put a light box slide show into one panel target, and another light box slide show into the next panel target, all works without any problem. No alert will be shown in this case.
Therefore I assume, that you are doing something else. But what?
Votes
Translate
Translate
Report
Report
New Here ,
Not a light box within a light box. I have a 5-tabbed panel in one page. My intent is to have a slideshow in each tab. That is all I'm doing.
Votes
Translate
Translate
Report
Report
LEGEND ,
May 24, 2017 May 24, 2017
LATEST
And exactly that works fine!
If not in your case, give us a .muse file with nothing else but this slideshow/tabbed panel construction (only one image in the slideshow, please) to have a look at: Upload this file to Dropbox or a similar file sharing service and post the download link here. Then we will see ā€¦
Votes
Translate
Translate
Report
Report
