• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Need help with blend mask.
Mentor ,
May 23, 2017 May 23, 2017
I know I've done this in the past, but everything I try becomes invisible...
but what I want to do is put the gradient ( blend ) in the "blue" letters.  Can someone help?
Views
382
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
Is the text outlined or still editable?
Or is this still a live envelope? In that case: make the text black and then create an opacity mask (check "Invert")
In case it's already outlined: make sure it's a compound path and then make a clipping mask
Votes
Translate
Translate
Report
Report
Mentor ,
Hi Monika. The blend is "live" and is behind outlined text. I did not create a compound path. Let me try that. I am using CD3.
Sent from my iPhone
Votes
Translate
Translate
Report
Report
Mentor ,
I was able to get the mask to work, however the centers of the "o" are still not open.  I am able to delete the center of the o and the number 0; but one of the o's refuses to release.  Should I expand the blend?
Votes
Translate
Translate
Report
Report
Community Expert ,
You don't need to touch the blend.
Can you maybe upload that Illustrator file somewhere, so we can take a look?
Votes
Translate
Translate
Report
Report
Advisor ,
Try applying a compound path to the "o" again with the center and the outer vectors selected, be sure the center of the character is the top most object of the two.
Votes
Translate
Translate
Report
Report
Mentor ,
Thank you both for your help.  I think it was a problem with the letters being grouped.  In a bind for time, I came up with this...
which, sad to say, was a matter of placing a gradient behind each letter separately and ungrouped.  Actually created a rectangle, angled it, and applied a new gradient direction on each to give the illusion of a blend.  I suspect had I more time, I could have done what I wanted and may still just to see if my theory holds water.
Votes
Translate
Translate
Report
Report
Mentor ,
No.  Even with letters ungrouped, I couldn't get the blend to work.  When I attempted to do the mask, only the exclamation point retained the blend.  Everything else dropped out.
Votes
Translate
Translate
Report
Report
Advisor ,
May 30, 2017 May 30, 2017
LATEST
Try making it a compound path or adding the Outline Object Effect to the type prior to using it as a mask.
Votes
Translate
Translate
Report
Report
