My CTI disappeared, as did the preview of the Compositions when I reopened it. I am on After Effect CC 2017 version 14.2.0.198 most recent updates are done. Please help
Moved from the non-technical Lounge Forum to the After Effects Forum for technical help
No clue of what you actually did, so no clue about what to tell you.
As I already said, I just opened the file and CTI and preview of Composition was gone. I had closed Ae, when I opened it again to work on it these was gone. I see this was an issue prior to one of the 2015 updates, is it an issue again?
Maybe you could look into it
Hit the home key. See if it shows up. You might have added a layer to the comp that extended beyond the comp's duration, and went to that layer's out point.
Still having trouble with this D3lirious? Please let us know.
Kevin
