4 Replies Latest reply on May 26, 2017 5:03 AM by gabrielg64889035
    Custom plugin not working (iOS)
    gabrielg64889035
      I have a custom Cordova plugin developed by a third party. I have created a test app for it and it works when compiled with Xcode, but not when compiled with PGB.
      The plugin is in a private GitHub repository and I have a PGB paid plan so I can use it.
      I have a test app that uses this plugin and builds fine (no errors) in the PGB service. The problem is that when I deploy and run it in my iPad, the app cannot communicate with the native plugin API. The following error can be seen in the iPad log:
      ERROR: Plugin 'MyPrivatePlugin' not found, or is not a CDVPlugin. Check your plugin mapping in config.xml.
      The plugin element in config.xml looks like this:
      <plugin name="my-private-plugin" spec="https://github.com/my-repository/my-plugin.git#0.0.5" />
      This are not the real names, but I am sure they are correctly matched in my plugin.xml file. Whan can be causing the problem then?
      As I have said, the app and plugin work when compiled in Xcode (the plugin developer aided me in testing this), but I don't have the skills to develop/maintain this app with PhoneGap CLI and Xcode, so I need to use PGB.
      Thank you!
        • 1. Re: Custom plugin not working (iOS)
          kerrishotts Adobe Employee
          Try using the PGB repo instead -- if you're paying, you should be able to upload your own plugins for private use. Last I knew a private github repo wasn't an option (but maybe that's changed...)
          • 2. Re: Custom plugin not working (iOS)
            vangroover Adobe Employee
            private plugin repos are not yet supported.  it's on our list, but currently your github oauth token isnt available for plugins.
            • 3. Re: Custom plugin not working (iOS)
              gabrielg64889035 Level 1
              I will try with a public repo then. Thanks.
              • 4. Re: Custom plugin not working (iOS)
                Hello Brett,
                I have tried with a public repo and I still get the error.
                This is the log produced at app start:
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: Apache Cordova native platform version 4.3.1 is starting.
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: Multi-tasking -> Device: YES, App: YES
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: Using UIWebView
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: [CDVTimer][handleopenurl] 0.414014ms
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: Unlimited access to network resources
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: [CDVTimer][intentandnavigationfilter] 4.769027ms
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: [CDVTimer][gesturehandler] 0.321984ms
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: [CDVTimer][TotalPluginStartup] 6.807983ms
                May 26 13:35:42 iPad-de-Josep TestRFID[1085] <Warning>: Resetting plugins due to page load.
                May 26 13:35:44 iPad-de-Josep TestRFID[1085] <Warning>: Finished load of: file:///var/containers/Bundle/Application/54BB35A7-9C3E-4486-9270-CEDAD622C88B/TestRFID.a pp/www/index.html
                May 26 13:35:45 iPad-de-Josep TestRFID[1085] <Warning>: ERROR: Plugin 'CaenRfidPlugin' not found, or is not a CDVPlugin. Check your plugin mapping in config.xml.
                This is my plugin, as specified in config.xml:
                <plugin name="tracetoo-plugin-caenrfid" spec="https://github.com/an3ss/pplgubg.git#0.0.5" />
                Any ideas?
