I have created a form in Acrobat where I assigned numerical values to specific check boxes, I then created a text box that added up those values (“TotalValue”); where I am stuck is in trying to tie the total value to a second text box that display a message based on the calculated value. Please note, I have zero knowledge or skill with JavaScript.
As the custom calculation script of the second field you can use something like this:
var totalValue = Number(this.getField("TotalValue").value);
if (totalValue==0) event.value = "";
else if (totalValue<=2) event.value = "Bad";
else if (totalValue<=5) event.value = "Medium";
else if (totalValue<=8) event.value = "Good";
else if (totalValue<=10) event.value = "Excellent";
I just invented the numeric values and the text descriptions... You can change them to your actual ones, of course.
Thanks! That worked perfectly!
