I have a listbox, which works fine when I use
var myBtn = w.add ("button", undefined, "Apply");
function updateButtons(){
// call this function whenever something changes in the ui that should prevent some buttons to be clickable
myBtn.enabled = (myList.selection !== null);
// and maybe some other buttons to update
myList.onChange = function(){
updateButtons();
// and maybe something else
myBtn.onClick = function(){
var listSel = myList.selection;
var myComp = app.project.activeItem;
if(!myComp || myComp.typeName !== "Composition") return;
var n;
for (n=0; n<listSel.length; n++){
var Text1 = "Text1";
var Text2 = listSel
ext;
This works fine.
But I want three separate listboxes, but rather than clutter the screen. I have tabbed then like so...
var tpanel = w.add('tabbedpanel');
tpanel.preferredSize = [350,300];
var top = tpanel.add('tab', undefined, "Tops");
top.add("listbox", [0,0,200,150], ["Jumper","T Shirt"], {
alignment: ['top','left'],
multiline:true,
multiselect:true,
numberOfColumns:2,
showHeaders: true,
columnTitles: ['Tops','value']
var bottom = tpanel.add('tab', undefined, "Bottoms");
bottom.add("listbox", [0,0,200,150], ["Trousers","Shorts"], {
multiline:true,
multiselect:true,
numberOfColumns:2,
showHeaders: true,
columnTitles: ['Bottoms','value']
var shoe = tpanel.add('tab', undefined, "Shoes");
shoe.add("listbox", [0,0,200,150], ["Sneakers","Ugg Boots"], {
multiline:true,
multiselect:true,
numberOfColumns:2,
showHeaders: true,
columnTitles: ['Shoes','value']
Inregards to this....var listSel = myList.selection;
I want to be able to change it on the lines of - var listSel = tpanel.shoes.selection
If someone knows the answer it would be much appreciated.
You can get to the listbox selection within your tpanel via the following:
selection = tpanel.children[0].children[0].selection;
Nearly there.
That worked from the moment I copied and pasted. Is there a way to Array it.
tpanel.children[1].children[0].selection;
tpanel.children[2].children[0].selection;
I've tried the obvious ways, but it doesn't seem to work, or it goes for the highest value being 2.
I figured how to do it. I realised that my for loop, I hadn't changed a letter.
