• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
CC Bend It Erases Image
Community Beginner ,
May 24, 2017 May 24, 2017
I'm trying to figure out CC Bend It. When I apply it to a layer it automatically erases half of the image. I'm attempting to animate a still graphic of an elephants trunk (on a separate layer). Any help would be greatly appreciated. Thanks!
Views
27.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , May 30, 2017 May 30, 2017
The puppet pin tool (read about it in the help) would probably be ideal for this.
Votes
Translate
Translate
LEGEND ,
May 25, 2017 May 25, 2017
Nothing unusual. CC Bend always affects the entire layer. You need to split out the trunk and adjust the start and end points accordingly or use otehr methods to begin with.
Mylenium
Votes
Translate
Translate
Report
Report
Thanks for the response!
What do you mean split out the trunk? Is there any other methods that could give me similar results?
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Awesome Szalam! Thank you!!!!!!!!
Votes
Translate
Translate
Report
Report
LEGEND ,
No problem! Glad to help.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 19, 2019 Apr 19, 2019
Alternatively you could add this expression to the start and end points:
toComp(value)
When you add this you might notice the "anchor points" going outside the comp area so you just need to drag them again to whichever position you want.
Votes
Translate
Translate
Report
Report
New Here ,
Sep 11, 2020 Sep 11, 2020
Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Jun 14, 2022 Jun 14, 2022
This was what I needed for my use case!! Thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 20, 2019 Apr 20, 2019
While I agree that Puppet Pin is also a good tool for this, you just need to reposition the points of the effect to suit your current needs. A lot of effects will have a default setting that doesn't necessarily do what you want; it's up to you to craft it to suit your project.
Votes
Translate
Translate
Report
Report
New Here ,
Feb 10, 2020 Feb 10, 2020
The CC Bend It effect affects the layer to its bounderies, so when you reach the end of the box of the layer, the image can´t go futher. You fix this by simply PRE-COMPOSE that layer. This way you can bend your layer to the limits of the Composition. PLUS ULTRA!
Votes
Translate
Translate
Report
Report
New Here ,
Sep 30, 2020 Sep 30, 2020
OMG I searched everywhere for this answer!!! Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
May 28, 2021 May 28, 2021
Thank a lot :') this is the BEST answer !!!
Votes
Translate
Translate
Report
Report
New Here ,
Feb 18, 2022 Feb 18, 2022
Even easier, you could use the "Grow bounds" effect!
Votes
Translate
Translate
Report
Report
New Here ,
May 29, 2020 May 29, 2020
Add "Grow Bounds" effects to the related layer make it like 1000px.
Done. Great solution.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 21, 2020 Jun 21, 2020
thanks a lot this fixed it for me!
Votes
Translate
Translate
Report
Report
Sep 23, 2021 Sep 23, 2021
Amazing solution! Worked perfectly for me. Thank you so much!
Votes
Translate
Translate
Report
Report
New Here ,
Sep 15, 2020 Sep 15, 2020
Adjust the start and end points at the corners in opposite fashion so that it entirely fills up the image then it works properly
Votes
Translate
Translate
Report
Report
New Here ,
Sep 03, 2021 Sep 03, 2021
Search "grow bound" on effects & presets then apply it on the working layer and increse the pixel size of  "grow bound". Hope it will fix your problem.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 27, 2023 Mar 27, 2023
LATEST
Try pre-compose the layer with [Move all attributes to a new composition] then apply the effect to the precomposition, it worked for me
Votes
Translate
Translate
Report
Report
