5 Replies Latest reply on Sep 26, 2008 8:35 AM by Newsgroup_User
    Help!  Need help translating AS3 to AS2!
    MrFrankZ
      Good afternoon. I have a very simple roll over animation that I want to use in Captivate 3. However, all of my experience with Flash is with AS3 which is not recognized by C3. Attached is my code snippet for the event that is not being supported. Would anyone be willing to tell me where to start to make this into AS2 (or 1)?
      Thank you in advance for any assistance.
        • 1. Re: Help!  Need help translating AS3 to AS2!
          Tekkaman_Slade Level 1
          It's using AS 2. Can you display all of the code?
          • 2. Re: Help!  Need help translating AS3 to AS2!
            MrFrankZ Level 1
            That is the entire code for the action. I have been reading into AS2 to AS3 migration, and unfortunately I have no idea about AS2 to draw my knowledge from. What it is is a simple mouse over animation that goes from frame label "notRolled" to "rolled" after the mouse passes over the defined rollBox. The compiler is "The class or interface 'MouseEvent' could not be loaded."
            Does that help any. Thanks in advance.
            • 3. Re: Help!  Need help translating AS3 to AS2!
              Level 7
              MrFrankZ,
              Here's the code from your first post, and I understand you'd like to
              convert it to ActionScript 2.0 (or even 1.0):
              >>> gotoAndPlay("notRolled");
              >>> rollBox.addEventListener(MouseEvent.MOUSE_OVER, onRoll);
              >>> function onRoll(event:MouseEvent):void
              >>> gotoAndPlay("rolled");
              >>> stop();
              To that, someone replied this:
              ... which turns out to be incorrect. The code you're showing is indeed AS3.
              Telltale signs include the MouseEvent class reference, the MOUSE_OVER event
              constant, and the lowercase :void reference.
              > loaded."
              That makes sense for a FLA file configured for AS2, because AS2 doesn't
              have a MouseEvent class. Fortunately, this is a simple scenario, so let's
              break it down.
              The first line doesn't change at all:
              That does the same thing in either AS2 or AS3; namely, it invokes the
              MovieClip.gotoAndPlay() method on a particular MovieClip instance (happens
              to be the timeline in which this code appears) and sends that movie clip's
              timeline to a frame labeled "notRolled".
              Wiring up the event handler is your biggest change. AS2 does support
              the addEventListener() method, but only for components. In AS2, there are
              (bewilderingly) five different ways to assign event handlers, and the one
              that's going to work here -- and feel most this AS3 version -- looks like
              this:
              rollBox.onRollOver = onRoll;
              In principle, it's doing the same thing. I'm assuming rollBox is a
              movie clip symbol, so to see what functionality has has available to it,
              you'll look up the MovieClip class in the ActionScript 2.0 Language
              Reference. When you do, you'll see headings for Properties (characteristics
              of the object), Methods (things the object can do), and Events (things the
              object can react to). A mouse-over is something the movie clip will react
              to, which makes it an event. What I've shown in my sample suggestion is the
              MovieClip.onRollOver event, as associated with your rollBox instance.
              The syntax is different from AS3, but the basic functionality is the
              same: "rollBox, when the mouse rolls over you, perform the onRoll()
              function."
              And now for that function:
              function onRoll():Void {
              Only two small changes: a) drop the event:MouseEvent parameter and b)
              change :void to :Void.
              Here it is altogether:
              // AS2
              And to make this work in AS2, all you have to do is drop the strong
              typing (in this case, the :Void):
              // AS1
              function onRoll() {
              David Stiller
              Co-author, The ActionScript 3.0 Quick Reference Guide
              http://tinyurl.com/2s28a5
              "Luck is the residue of good design."
              • 4. Re: Help!  Need help translating AS3 to AS2!
                MrFrankZ Level 1
                I wish I would have had a chance to work with Flash pre-AS3! Your help is greatly appreciated. I thank you, and my company REALLY thanks you.
                • 5. Re: Help!  Need help translating AS3 to AS2!
                  Level 7
                  MrFrankZ,
                  You still have that chance. ;)
                  > REALLY thanks you.
                  Glad to help!
                  David Stiller
                  Adobe Community Expert
                  Dev blog, http://www.quip.net/blog/
