1 Reply Latest reply on May 25, 2017 10:23 AM by johnrellis
    Detect Develop changes in plugin.
    darylt46915580 Level 1
      I am currently working on an export plugin and I need to be able to detect if a photo has had any changes made in Develop. Currently I am using the editCount metadata but that is proving to be a bit more generous in what it considers edits than I would prefer
      Does anyone have another suggestion I could consider?
      -daryl
        • 1. Re: Detect Develop changes in plugin.
          johnrellis Most Valuable Participant
          Yeah, "editCount" gets incremented when metadata is changed as well as develop settings.
          Your plugin could examine the values returned by photo:getDevelopSettings() for any that are not the default value.
          But this will also flag photos as "changed" if the camera default develop settings have been changed by Develop > Set Default Settings, even if the user hasn't explicitly changed a develop slider.  If that's not what you want, then the plugin would need to determine the current values for those camera-default settings. The only way I can think of for doing that is to import a dummy photo from the same camera model and check photo:getDevelopSettings ().
