3 Replies Latest reply on May 26, 2017 11:57 AM by alexanderm82
    Online stream stops in HTML5 Android 7.1
    alexanderm82 Level 1
      Hello, I've built an app using jplayer and HTML5. Everything works fine for older versions of Android, but in Android 7.1, playback of online streams stops after 4 minutes and some seconds, every time screen goes off. If I turn the screen on soon after stopping, playback continues. It's not a player issue, as I've tried using numerous other players, but not jplayer. The issue is the same when using the <audio> tag. Can you please help me out?
        • 1. Re: Online stream stops in HTML5 Android 7.1
          P.S. I just found out, that the issue is related to the new battery optimization of Android. If I switch it off for the specific app, there are no issues. But I don't know what am I supposed to do, in order for the app to run without switching off battery optimization manually?
          • 2. Re: Online stream stops in HTML5 Android 7.1
            audreyeso Adobe Employee
            Hi! If you could provide a code sample, that would be awesome! Thank so much!
            • 3. Re: Online stream stops in HTML5 Android 7.1
              Hello audreyeso, thank you so much for the attention.
              It's a simple HTML code, which I managed to turn into an app thanks to Phonegap. But now with the Battery optimization in Nougat the internet connection for the app stops every 4 minutes after screen is off, and I don't know what to do...
              Here is the code:
              index.html -
              <!DOCTYPE html>
              <html>
              <head>
              <meta http-equiv="Content-Security-Policy" content="default-src *; style-src 'self' 'unsafe-inline'; script-src 'self' 'unsafe-inline' 'unsafe-eval'">
              <script type="text/javascript" src="cordova.js"></script>
              <meta name="format-detection" content="telephone=no" />
              <meta name="viewport" content="user-scalable=no, initial-scale=1, maximum-scale=1, minimum-scale=1, width=device-width" />
              <title>Radio Online</title>
              <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
              <link href="dist/skin/pink.flag/css/jplayer.pink.flag.min.css" rel="stylesheet" type="text/css" />
              <script type="text/javascript" src="lib/jquery.min.js"></script>
              <script type="text/javascript" src="dist/jplayer/jquery.jplayer.min.js"></script>
              <script type="text/javascript" src="dist/add-on/jplayer.playlist.min.js"></script>
              <script type="text/javascript" charset="utf-8">
              document.addEventListener("deviceready", onDeviceReady, false);
              function onDeviceReady() {
                  document.addEventListener("backbutton", onBackKeyDown, false); //Listen to the User clicking on the back button
              function onBackKeyDown(e) {
                  e.preventDefault();
                  navigator.notification.confirm("Are you sure you want to exit?", onConfirm, "Confirmation", "Yes,No");
                  // Prompt the user with the choice
              function onConfirm(button) {
                  if(button==2){//If User selected No, then we just do nothing
                      return;
                  }else{
                      navigator.app.exitApp();// Otherwise we quit the app.
              </script>
              var delay=2000;
              setTimeout(function(){
              //<![CDATA[
              $(document).ready(function(){
              new jPlayerPlaylist({
              jPlayer: "#jquery_jplayer_1",
              cssSelectorAncestor: "#jp_container_1"
              title:"title",
              mp3:"http://xx.xx.xx.xx:8000/;play.mp3"
              title:"title2",
              mp3:"http://xxx.xxx.xxx.xxx:8000/;play.mp3"
              swfPath: "../../dist/jplayer",
              supplied: "oga, mp3",
              wmode: "window",
              useStateClassSkin: true,
              autoBlur: false,
              smoothPlayBar: true,
              keyEnabled: true,
              }, delay);
              </script>
              </head>
              <body onload="onLoad()" onresize="onResize()" bgcolor="#26102e" style="margin:0px; background-size: 100% 100%; background-position:100% 100%; width: 100%; height: 100%; margin: 0; padding: 0; overflow: hidden; background-color:#26102e;" >
              <div id="jquery_jplayer_1" class="jp-jplayer"></div>
              <div id="jp_container_1" class="jp-audio" role="application" aria-label="media player">
              <div class="jp-type-playlist" >
              <div class="jp-gui jp-interface">
              <div class="jp-controls-holder">
              <div class="jp-controls">
              <button class="jp-previous" role="button" tabindex="0">previous</button>
              <button class="jp-play" role="button" tabindex="0">play</button>
              <button class="jp-stop" role="button" tabindex="0">stop</button>
              <button class="jp-next" role="button" tabindex="0">next</button>
              </div>
              <div class="jp-progress">
              <div class="jp-seek-bar">
              <div class="jp-play-bar"></div>
              </div>
              </div>
              </div>
              </div>
              <div class="jp-playlist" >
              <ul>
              <li> </li>
              </ul>
              </div>
              </div>
              </div>
              </body>
              </html>
              This is my config.xml:
              <widget xmlns="http://www.w3.org/ns/widgets" xmlns:gap="http://phonegap.com/ns/1.0" id="radio.radio" version="1.11.1">
                <name>Radio</name>
                <description>Radios online</description>
                <author href="http://www.www.com" email="www@www.com">Company Ltd.</author>
                <content src="index.html"/>
                <preference name="permissions" value="none"/>
                <preference name="phonegap-version" value="cli-6.5.0"/>
                <preference name="orientation" value="portrait"/>
                <preference name="target-device" value="universal"/>
                <preference name="fullscreen" value="false"/>
                <preference name="webviewbounce" value="true"/>
                <preference name="prerendered-icon" value="true"/>
                <preference name="stay-in-webview" value="false"/>
                <preference name="ios-statusbarstyle" value="black-opaque"/>
                <preference name="detect-data-types" value="true"/>
                <preference name="exit-on-suspend" value="false"/>
                <preference name="show-splash-screen-spinner" value="true"/>
                <preference name="auto-hide-splash-screen" value="true"/>
                <preference name="disable-cursor" value="false"/>
                <preference name="android-minSdkVersion" value="14"/>
                <preference name="android-installLocation" value="auto"/>
              <plugin name="cordova-plugin-console" source="npm"/>
              <plugin name="cordova-plugin-dialogs" source="npm"/>
              <plugin name="cordova-plugin-splashscreen" source="npm"/>
              <preference name="show-splash-screen-spinner" value="true" />
                  <preference name="auto-hide-splash-screen" value="true" />
              <preference name="SplashScreenDelay" value="5000" />
              <gap:splash src="splashscreen.jpg" />
              <preference name="android-build-tool" value="gradle" />
              <plugin name="cordova-plugin-admobpro" source="npm" />
                <access origin="*"/>
              <plugin name="cordova-plugin-whitelist" source="npm" />
                  <allow-intent href="http://*/*" />
                  <allow-intent href="https://*/*" />
                  <platform name="android">
                      <allow-intent href="market:*" />
                  </platform>
                <icon src="icon.png"/>
                <icon src="icon1.png" gap:platform="android" gap:qualifier="ldpi"/>
                <icon src="icon2.png" gap:platform="android" gap:qualifier="mdpi"/>
                <icon src="icon3.png" gap:platform="android" gap:qualifier="hdpi"/>
                <icon src="icon4.png" gap:platform="android" gap:qualifier="xhdpi"/>
                <gap:splash src="www/res/screen/android/screen-ldpi-portrait.png" gap:platform="android" gap:qualifier="port-ldpi"/>
                <gap:splash src="www/res/screen/android/screen-mdpi-portrait.png" gap:platform="android" gap:qualifier="port-mdpi"/>
                <gap:splash src="www/res/screen/android/screen-hdpi-portrait.png" gap:platform="android" gap:qualifier="port-hdpi"/>
                <gap:splash src="www/res/screen/android/screen-xhdpi-portrait.png" gap:platform="android" gap:qualifier="port-xhdpi"/>
                <gap:splash src="www/res/screen/blackberry/screen-225.png" gap:platform="blackberry"/>
                <gap:splash src="www/res/screen/ios/screen-iphone-portrait.png" gap:platform="ios" width="320" height="480"/>
                <gap:splash src="www/res/screen/ios/screen-iphone-portrait-2x.png" gap:platform="ios" width="640" height="960"/>
                <gap:splash src="www/res/screen/ios/screen-iphone-portrait-568h-2x.png" gap:platform="ios" width="640" height="1136"/>
                <gap:splash src="www/res/screen/ios/screen-ipad-portrait.png" gap:platform="ios" width="768" height="1024"/>
                <gap:splash src="www/res/screen/ios/screen-ipad-landscape.png" gap:platform="ios" width="1024" height="768"/>
                <gap:splash src="www/res/screen/windows-phone/screen-portrait.jpg" gap:platform="winphone"/>
              </widget>
              I'm not really into coding, so I'd be really grateful, if yet some solution exists...
              Thank you in advance!
              Alexander
