I've been working on a file. I have suddenly lost the ability to select individual layers in that file; i.e., selecting a layer does not highlight the layer. I can toggle the visibility of the layer; however, alt+click will not hide all other layers. I can not activate a mask on a layer. Strangely, I can click on a layer, then shift+click on some other layer in the stack to select (and highlight) a group of layers. If I duplicate that group into a new document, all operations are normal (highlight a single layer, move from image to mask, alt+click, etc.). So, it's something to do with that particular file. No layers are locked. No auto select.
I can easily work around by just duplicating all layers into a new document. Then, everything is back to normal. But I would like to know what might be causing the problem just to further my understanding. Any insight would be greatly appreciated.
You seem to have activated Quick Mask Mode (Q).
Could you please post a screenshot taken at View > 100% and with the pertinent Panels (Layers, Channels, Options Bar, …) visible?
Thanks for the reply. The first image is from a 4K screen, the second may be easier to read.
Thanks very much.
