The program and source monitors stay frozen on a single frame even though the timeline is playing back smoothly and I can hear the audio. If I double click on the program monitor, the frame will refresh to wherever the timeline marker is placed. But when I press play, nothing. This issue has only crept up in the past week and I've exhausted my options including speaking with technical support (case#188977896). He suggested I create a new user account in windows 10, but I can't do that until next week when our IT guy comes in. I need to use the program asap so I'm throwing out there to the community to see if anyone has had a similar issue.
Whats odd is that it happens in CC2017, CC2015, and CS6. This leads me to believe its an issue with my system. I haven't changed anything in the past week that I can recall that would cause this.
Much love and appreciation for your time. I will reply with any additional info you may need!
I fixed the issue by going to my Nvidia control panel, "Manage 3D settings", selecting the "Program Settings" tab, and changing "Select the preferred graphics processor for this program" to "Integrated Graphics". After that, the program started working normally again, even after resetting it back to the Nvidia GPU.
I had an inkling that there was some conflict due to having two GPUs, the integrated and the Nvidia Quadro, both active at the same time. This is apparently done as a power saving feat
...Copy link to clipboard
Is this with all projects or just the one?
Neil
Thank you, all projects sir.
Often when something similar has come it, it has been involved with the audio drivers and/or GPU. Perhaps your audio drivers or GPU driver updated?
You might try changing the Audio setup/preferences in the Preferences file, and/or rolling back a driver version for the audio or GPU.
First, you might try changing the Mercury Acceleration item in the preferences from "cuda" or OpenCL to "Software Only".
Guessing, but ... these are often involved.
But if someone's got a more direct idea ...
Neil
Changing the Mercury Acceleration settings didn't work. I'm working on rolling back the driver versions and will see if that makes a difference.
What happens if you set the Program Monitor's playback resolution to its lowest setting of 1/16? It's the dropdown at the bottom, just to the left of the wrench icon. This will help distinguish between a performance issue and a basic functional issue.
Thanks, when clicking the dropdown I only see options for full, 1/2 and 1/4. Setting it to 1/4 makes no difference. I'm wondering why I don't see 1/16?
Here is a general guide you can work through. Something in it might help.
I had this same issue all the time on 2015 and frankly that is the entire reason I upgraded to 2017. "Upgraded". Except this version doesn't work either, but that specific issue I haven't encountered yet. Just new ones.
I had an inkling that there was some conflict due to having two GPUs, the integrated and the Nvidia Quadro, both active at the same time. This is apparently done as a power saving feature, so the Quadro is only used when its needed. It was also really strange that the video would refresh only when I clicked in the program monitor. By rapidly clicking in the monitor I could see the video refresh each time, which led to me believe it was some sort of bug.
Anyways, I'm not sure how or why this fixed the issue, but I am up and running again. Thanks to all who offered assistance.
Dual GPUs do cause the program & OS to act confused at times. Good catch!
Neil
So i have the exact same issue with my system, however, I'm running OSX and hence I have AMD GPU. Specifically the 2018 MB Pro Radeon Vega 20 4GB. I have the system set to always use GPU (uncheck the option in energy settings to automatically switch GPU). I have just started another post. But if anyone else has info on how to fix. Please post. I'm trying to install an older version of CC PP V13 now.
