12 Replies Latest reply on Jul 21, 2017 5:51 AM by Alex Jester
    Build failed
    dexterp23
      Few hours ago I build app with no problem. Now I have build failed and files are the same as few hours ago.
      Can you help me with this?
      Log file:
      Build Date: 2017-05-26 20:28:48 +0000
      Configuration on demand is an incubating feature.
      FAILURE: Build failed with an exception.
      * What went wrong:
      A problem occurred configuring root project 'project'.
      > Could not resolve all dependencies for configuration ':_debugCompile'.
        > Could not find com.android.support:support-v4:25.3.1.
        Searched in the following locations:
        https://repo1.maven.org/maven2/com/android/support/support-v4/25.3.1/support-v4-25.3.1.pom
        https://repo1.maven.org/maven2/com/android/support/support-v4/25.3.1/support-v4-25.3.1.jar
        file:/android-sdk/extras/android/m2repository/com/android/support/support-v4/25.3.1/suppo rt-v4-25.3.1.pom
        file:/android-sdk/extras/android/m2repository/com/android/support/support-v4/25.3.1/suppo rt-v4-25.3.1.jar
        file:/android-sdk/extras/google/m2repository/com/android/support/support-v4/25.3.1/suppor t-v4-25.3.1.pom
        file:/android-sdk/extras/google/m2repository/com/android/support/support-v4/25.3.1/suppor t-v4-25.3.1.jar
        Required by:
        :project:unspecified
        Required by:
        :project:unspecified > com.android.support:support-v13:23.4.0
        Required by:
        :project:unspecified > com.facebook.android:facebook-android-sdk:4.23.0
        > Could not find com.android.support:appcompat-v7:25.3.1.
        https://repo1.maven.org/maven2/com/android/support/appcompat-v7/25.3.1/appcompat-v7-25.3.1 .pom
        https://repo1.maven.org/maven2/com/android/support/appcompat-v7/25.3.1/appcompat-v7-25.3.1 .jar
        file:/android-sdk/extras/android/m2repository/com/android/support/appcompat-v7/25.3.1/app compat-v7-25.3.1.pom
        file:/android-sdk/extras/android/m2repository/com/android/support/appcompat-v7/25.3.1/app compat-v7-25.3.1.jar
        file:/android-sdk/extras/google/m2repository/com/android/support/appcompat-v7/25.3.1/appc ompat-v7-25.3.1.pom
        file:/android-sdk/extras/google/m2repository/com/android/support/appcompat-v7/25.3.1/appc ompat-v7-25.3.1.jar
        Required by:
        > Could not find com.android.support:cardview-v7:25.3.1.
        https://repo1.maven.org/maven2/com/android/support/cardview-v7/25.3.1/cardview-v7-25.3.1.p om
        https://repo1.maven.org/maven2/com/android/support/cardview-v7/25.3.1/cardview-v7-25.3.1.j ar
        file:/android-sdk/extras/android/m2repository/com/android/support/cardview-v7/25.3.1/card view-v7-25.3.1.pom
        file:/android-sdk/extras/android/m2repository/com/android/support/cardview-v7/25.3.1/card view-v7-25.3.1.jar
        file:/android-sdk/extras/google/m2repository/com/android/support/cardview-v7/25.3.1/cardv iew-v7-25.3.1.pom
        file:/android-sdk/extras/google/m2repository/com/android/support/cardview-v7/25.3.1/cardv iew-v7-25.3.1.jar
        Required by:
        > Could not find com.android.support:customtabs:25.3.1.
        https://repo1.maven.org/maven2/com/android/support/customtabs/25.3.1/customtabs-25.3.1.pom
        https://repo1.maven.org/maven2/com/android/support/customtabs/25.3.1/customtabs-25.3.1.jar
        file:/android-sdk/extras/android/m2repository/com/android/support/customtabs/25.3.1/custo mtabs-25.3.1.pom
        file:/android-sdk/extras/android/m2repository/com/android/support/customtabs/25.3.1/custo mtabs-25.3.1.jar
        file:/android-sdk/extras/google/m2repository/com/android/support/customtabs/25.3.1/custom tabs-25.3.1.pom
        file:/android-sdk/extras/google/m2repository/com/android/support/customtabs/25.3.1/custom tabs-25.3.1.jar
        Required by:
        Required by:
        :project:unspecified > com.google.android.gms:play-services-gcm:10.2.0 > com.google.android.gms:play-services-basement:10.2.0
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 1.087 secs
      undefined
        • 1. Re: Build failed
          canados Level 1
          Hello
          I have kind of the same problem. Do you happen to use a facebook plugin ?
          • 3. Re: Build failed
            canados Level 1
            ok then look no further. Facebook changed their Android SDK and now the  compiler is failing !
            I sent a message to phonegapbuild on twitter as I believe they tends to reply faster that way. I suggest you do the same
            Regards
            • 4. Re: Build failed
              canados Level 1
              hello dexterp23
              maybe you can join this tweet
              https://twitter.com/PhoneGapBuild/status/868274115454451712
              It will fix the bug faster if there is more complains : )
              • 5. Re: Build failed
                dexterp23 Level 1
                Yes, it is Facebook plugin issue.
                I will join this tweet.
                • 6. Re: Build failed
                  dexterp23 Level 1
                  any update on this issue?
                  • 7. Re: Build failed
                    Gabit_Zhake Level 1
                    Is there a built-in plug-in in https: //build.phonegap.com?
                    • 8. Re: Build failed
                      vangroover Adobe Employee
                      if you're using cordova-plugin-facebook4 it should be fixed. it takes a while for the android SDK to be updated on PhoneGap Build as we have testing procedures to go through.
                      • 9. Re: Build failed
                        dexterp23 Level 1
                        Yes I use cordova-plugin-facebook4 but when I build with that plugin now I get this error:
                        Build Date: 2017-06-16 22:43:30 +0000
                        :preBuild UP-TO-DATE
                        :preReleaseBuild UP-TO-DATE
                        :checkReleaseManifest
                        :preDebugBuild UP-TO-DATE
                        :CordovaLib:preBuild UP-TO-DATE
                        :CordovaLib:preDebugBuild UP-TO-DATE
                        :CordovaLib:compileDebugNdk UP-TO-DATE
                        :CordovaLib:compileLint
                        :CordovaLib:copyDebugLint UP-TO-DATE
                        :CordovaLib:mergeDebugProguardFiles
                        :CordovaLib:packageDebugRenderscript UP-TO-DATE
                        :CordovaLib:checkDebugManifest
                        :CordovaLib:prepareDebugDependencies
                        :CordovaLib:compileDebugRenderscript
                        :CordovaLib:generateDebugResValues
                        :CordovaLib:generateDebugResources
                        :CordovaLib:packageDebugResources
                        :CordovaLib:compileDebugAidl
                        :CordovaLib:generateDebugBuildConfig
                        :CordovaLib:generateDebugAssets UP-TO-DATE
                        :CordovaLib:mergeDebugAssets
                        :CordovaLib:processDebugManifest
                        :CordovaLib:processDebugResources
                        :CordovaLib:generateDebugSources
                        :CordovaLib:compileDebugJavaWithJavacNote: Some input files use or override a deprecated API.
                        Note: Recompile with -Xlint:deprecation for details.
                        :CordovaLib:processDebugJavaRes UP-TO-DATE
                        :CordovaLib:transformResourcesWithMergeJavaResForDebug
                        :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
                        :CordovaLib:mergeDebugJniLibFolders
                        :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
                        :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
                        :CordovaLib:bundleDebug
                        :CordovaLib:preReleaseBuild UP-TO-DATE
                        :CordovaLib:compileReleaseNdk UP-TO-DATE
                        :CordovaLib:copyReleaseLint UP-TO-DATE
                        :CordovaLib:mergeReleaseProguardFiles
                        :CordovaLib:packageReleaseRenderscript UP-TO-DATE
                        :CordovaLib:checkReleaseManifest
                        :CordovaLib:prepareReleaseDependencies
                        :CordovaLib:compileReleaseRenderscript
                        :CordovaLib:generateReleaseResValues
                        :CordovaLib:generateReleaseResources
                        :CordovaLib:packageReleaseResources
                        :CordovaLib:compileReleaseAidl
                        :CordovaLib:generateReleaseBuildConfig
                        :CordovaLib:generateReleaseAssets UP-TO-DATE
                        :CordovaLib:mergeReleaseAssets
                        :CordovaLib:processReleaseManifest
                        :CordovaLib:processReleaseResources
                        :CordovaLib:generateReleaseSources
                        :CordovaLib:compileReleaseJavaWithJavacNote: Some input files use or override a deprecated API.
                        :CordovaLib:processReleaseJavaRes UP-TO-DATE
                        :CordovaLib:transformResourcesWithMergeJavaResForRelease
                        :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
                        :CordovaLib:mergeReleaseJniLibFolders
                        :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
                        :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
                        :CordovaLib:bundleRelease
                        :prepareComAndroidSupportAnimatedVectorDrawable2531Library
                        :prepareComAndroidSupportAppcompatV72531Library
                        :prepareComAndroidSupportCardviewV72531Library
                        :prepareComAndroidSupportCustomtabs2531Library
                        :prepareComAndroidSupportSupportCompat2531Library
                        :prepareComAndroidSupportSupportCoreUi2531Library
                        :prepareComAndroidSupportSupportCoreUtils2531Library
                        :prepareComAndroidSupportSupportFragment2531Library
                        :prepareComAndroidSupportSupportMediaCompat2531Library
                        :prepareComAndroidSupportSupportV132340Library
                        :prepareComAndroidSupportSupportV42531Library
                        :prepareComAndroidSupportSupportVectorDrawable2531Library
                        :prepareComFacebookAndroidFacebookAndroidSdk4230Library
                        :prepareComGoogleAndroidGmsPlayServicesBase1100Library
                        :prepareComGoogleAndroidGmsPlayServicesBasement1100Library
                        :prepareComGoogleAndroidGmsPlayServicesGcm1100Library
                        :prepareComGoogleAndroidGmsPlayServicesIid1100Library
                        :prepareComGoogleAndroidGmsPlayServicesTasks1100Library
                        :prepareProjectCordovaLibUnspecifiedReleaseLibrary
                        :compileReleaseAidl
                        :mergeReleaseAssets
                        :mergeReleaseResources
                        :processReleaseResources/project/build/intermediates/res/merged/release/values-v24/values- v24.xml:3 : AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
                        /project/build/intermediates/res/merged/release/values-v24/values-v24.xml:4 : AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Colored'.
                        FAILED
                        * What went wrong:
                        Execution failed for task ':processReleaseResources'.
                        > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/android-sdk/build-tools/24.0.1/aapt'' finished with non-zero exit value 1
                        * Try:
                        BUILD FAILED
                        Total time: 7.444 secs
                        undefined
                        • 10. Re: Build failed
                          try updating your phonegap version to cli-6.5.0
                          • 11. Re: Build failed
                            dexterp23 Level 1
                            That is the solution.
                            thank you
                            • 12. Re: Build failed
                              Alex Jester
                              I still get the build error for Android and sometimes for iOS... as soon as I take out the dumb facebook plugin it works.
                              My client insists to have that feature :/
                              I can't get it to work on Android no matter what I do
