6 Replies Latest reply on May 28, 2017 5:59 PM by Segref
    Slow computer after LR6 upgrade to .10
    Segref
      Today, after installing LR 6.10 I started getting low memory warnings and "turn off Lightroom". A few tests later I determined that Lightroom is the cause of all my troubles.
      Even with LR minimised the "C" drive was still running at 100% and memory usage was around 85%.
      LR was locking up 3.3GB of memory. I have 8GB ram and this has never caused a problem.
      Switching LR off reduced disk usage to 4% and memory to 35%. Switching LR back on caused 100% disk and higher memory usage.
      I repeated this sequence a number of times with the same result each time.
      A second reboot after the upgrade saw the memory usage drop but the HDD usage stayed at 100%.
      1) Why is this happening?
      2) Can I migrate Lightroom to a different hard drive on my computer?
      3) How can I reduce the resources that LR seems to require even when not in use?
      I am running the latest upgrade of Windows 10.
