Bug tracker link: Tracker
Problem Description:
When you use AdjustColor and set all it properties then set again brightness or hue to 0 value in result you get that AdjustColor::CalculateFinalFlatArray() method don't change it result.
It's very old bug described even there in 2012 (4 years ago!): http://stackoverflow.com/questions/10172393/as3-adjust-image-colors
It has been tested with many different Flash Player and AIR versions from 10.3 to 22 beta. The same problem in all cases.
It's a big problem for work with filters.
Steps to Reproduce:
1) Create AdjustColor object
2) Set it properties (brightness, contrast, hue and saturation) with values
3) Set again (change) brightness or hue value to 0.
4) get AdjustColor::CalculateFinalFlatArray() method result
Launch code below. Application example with sources attached.
ActionScript 3.0 code:
var adjustColor:AdjustColor = new AdjustColor();
adjustColor.brightness = 50;
adjustColor.contrast = 0;
adjustColor.hue = 0;
adjustColor.saturation = 0;
trace("Before changes:", adjustColor.CalculateFinalFlatArray());//Before changes: 1,0,0,0,50,0,1,0,0,50,0,0,1,0,50,0,0,0,1,0
adjustColor.brightness = 0;
trace("Actual result:", adjustColor.CalculateFinalFlatArray());//Actual result: 1,0,0,0,50,0,1,0,0,50,0,0,1,0,50,0,0,0,1,0
adjustColor = new AdjustColor();
trace("Expected result:", adjustColor.CalculateFinalFlatArray());//Expected result: 1,0,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,1,0
Actual Result:
Expected Result:
Any Workarounds: recreate AdjustColor instead of reuse it:
This issue still exists with latest AIR 27.0.0.116 beta and Animate CC 2017.5
This issue still exists with latest AIR 29.0.0.96 beta and Animate CC 18.0.1
