4 Replies Latest reply on Jun 15, 2017 11:48 AM by Szalam
    After Effects Crash on OSX 10.12.5
    boz2008
      Updated OSX and every time I start After Effects i crashes on a OSX 10.12.5 on Mac Pro Early 2009.
      Tried to reinstall, tried to remove all preferences under /User Home/Preferences/Adobe/After Effects and emptied trash bin,
      did a restart, reinstalled and so on.
      No Success:
      Updated the NVIDIA Cuda and Graphic card drivers, reversed them to OSX Nvidia graphic card.
      No Success:
      Does anyone have more smart suggestion for me to try out?
      Regards Boz
      Logg:
      Process:               After Effects [772]
      Path:                  /Applications/Adobe After Effects CC 2017/Adobe After Effects CC 2017.app/Contents/MacOS/After Effects
      Identifier:            com.adobe.AfterEffects
      Version:               14.2 (14.2)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           After Effects [772]
      User ID:               502
      Date/Time:             2017-05-28 16:27:50.811 +0200
      OS Version:            Mac OS X 10.12.5 (16F73)
      Report Version:        12
      Anonymous UUID:        C9C67438-DD6E-50B1-E5B2-011447BAFFE2
      Time Awake Since Boot: 530 seconds
      System Integrity Protection: enabled
      Crashed Thread:        0  Dispatch queue: com.apple.main-thread
      Exception Type:        EXC_CRASH (SIGABRT)
      Exception Codes:       0x0000000000000000, 0x0000000000000000
      Exception Note:        EXC_CORPSE_NOTIFY
      Application Specific Information:
      abort() called
      terminating with uncaught exception of type dvacore::filesupport::dir_exception: dva_exception::what() error.
      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
      0   libsystem_kernel.dylib         0x00007fffc8f44d42 __pthread_kill + 10
      1   libsystem_pthread.dylib       0x00007fffc9032457 pthread_kill + 90
      2   libsystem_c.dylib             0x00007fffc8eaa420 abort + 129
      3   libc++abi.dylib               0x00007fffc7a0484a abort_message + 266
      4   libc++abi.dylib               0x00007fffc7a29c37 default_terminate_handler() + 243
      5   libobjc.A.dylib               0x00007fffc8537353 _objc_terminate() + 124
      6   libc++abi.dylib               0x00007fffc7a26d69 std::__terminate(void (*)()) + 8
      7   libc++abi.dylib               0x00007fffc7a26de3 std::terminate() + 51
      8   com.adobe.AfterEffects         0x00000001098b0eab main + 2267
      9   com.adobe.AfterEffects         0x00000001098b05c4 start + 52
      Model: MacPro5,1, BootROM MP51.007F.B03, 8 processors, Quad-Core Intel Xeon, 2,26 GHz, 16 GB, SMC 1.39f5
      Graphics: NVIDIA Quadro 4000, NVIDIA Quadro 4000, PCIe, 2048 MB
      Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
      Memory Module: DIMM 2, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
      Memory Module: DIMM 3, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030322E4130324C4620
      Memory Module: DIMM 4, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030322E4130324C4620
      Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
      Memory Module: DIMM 6, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
      Memory Module: DIMM 7, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030322E4130324C4620
      Memory Module: DIMM 8, 2 GB, DDR3 ECC, 1066 MHz, 0x0198, 0x393930353431332D3030322E4130324C4620
      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.24)
      Bluetooth: Version 5.0.4f18, 3 services, 27 devices, 1 incoming serial ports
      Network Service: Ethernet 1, Ethernet, en0
      Network Service: Wi-Fi, AirPort, en2
      PCI Card: NVIDIA Quadro 4000, Display Controller, Slot-1
      PCI Card: NVIDIA Quadro 4000, NVDA,Parent, Slot-1
      PCI Card: pci1b4b,9182, AHCI Controller, Slot-2
      Serial ATA Device: HL-DT-ST DVD-RW GH41N
      Serial ATA Device: Samsung SSD 850 PRO 256GB, 256,06 GB
      Serial ATA Device: WDC WD20EARS-00MVWB0, 2 TB
      Serial ATA Device: ST2000DL003-9VT166, 2 TB
      Serial ATA Device: Hitachi HDS721010KLA330, 1 TB
      USB Device: USB Bus
      USB Device: USB Bus
      USB Device: USB Bus
      USB Device: BRCM2046 Hub
      USB Device: Bluetooth USB Host Controller
      USB Device: USB Bus
      USB Device: USB Bus
      USB Device: USB-PS/2 Optical Mouse
      USB Device: USB Bus
      USB Device: USB 2.0 Bus
      USB Device: ImageMate 14 in 1 Reader/Writer
      USB Device: Keyboard Hub
      USB Device: Apple Keyboard
      FireWire Device: built-in_hub, Up to 800 Mb/sec
      Thunderbolt Bus:
