5 Replies Latest reply on Jan 8, 2018 2:45 AM by Real estate photo editing
    How to retouch real estate photos?
    prettyjoe Level 1
      I am new here on this forum. I know how to use photoshop pretty wel, but I wonder if anybody has some advanced tips for real estate retouching....especially that white look these retouchers achieve. I have been playing with photoshop for a while and I can not get it right....
      for example this example
      if somebody can give me few tips, please do so......
        • 1. Re: How to retouch real estate photos?
          Barbara Ash Adobe Community Professional
          The white look is probably achieved by using gray point eyedropper which can be found in Camera Raw, in the Levels, or Curves panel.
          First select the Eyedropper in the Tools panel. It is usually helpful to set it to 3 x 3 or 5 x 5 to get better averaging. The setting of the regular Eyedropper will affect all eyedroppers.
          Then open Levels or Curves or Camera Raw and select the gray point Eyedropper.
          With that eyedropper, click on a pixel that you think should be neutral You may need to click on a few different pixels before finding the best area.
          On the image below, I clicked on the sofa
          Unfortunately, there are multiple color casts on the wall, so to make the wall more neutral, I chose Select > Color range and targeted the highlights.
          Then in the Hue/Saturation panel, desaturated the selected areas to make them more neutral.
          ... and came up with this:
          I would suggest making all of your edits on Adjustment layers so that you can easily change them afterwards.
          Each image is different and therefore needs to be treated somewhat differently, but these techniques should get you started in the right direction.
          • 3. Re: How to retouch real estate photos?
            Chuck Uebele Adobe Community Professional & MVP
            If you not shooting the images, then Barbara had some very good tips. Basically Masking and neutralizing various areas of the image.
            If you're shooting the photos, one trick you can use is to flood the room with strobe light. You can either do this with one exposure or multiple exposures and combine them using lightness mode. Then you can shoot an ambient light shot or an HDR to get full dynamic range. Take the flash shot and put that above the ambient shot and set the blend mode to color. Thus you get the clean color of the flash, but the light shading of the ambient lighting. You can also adjust the opacity to bring back some of the original color of the ambient light For example, the below images had soft white bulbs, which were very yellow, combined with the blue light from outside. I shot multiple flash shots and used the above technique to balance the interior and exterior lights, and make the light look cleaner and whiter. (Note the paint in the family room was yellow, so I didn't want to make it look white.)
            Image may contain: indoor
            Image may contain: living room, table and indoor
            • 4. Re: How to retouch real estate photos?
              legacylocatorsdfw
              Thank you for sharing this!
              • 5. Re: How to retouch real estate photos?
                Did you find your own way to do it?
