3 Replies Latest reply on May 29, 2017 3:38 AM by Obi-wan Kenobi
    find between brackets
    gert verrept Level 2
      FIND
      \(([^()]|(?R))*\)
      CHANGE
      italic (char style)
      gives
      (sunt quaepta (tiorepta perovit aliquibus) dem)
      The grep above finds what is between brackets, but I want it to find the whole text between the exterior brackets, but without the brackets.
      getting it so:
        • 1. Re: find between brackets
          This will do the job, but extremely literally: it will only and exclusively match the outer parenthesized phrase (sans parens) when there is a single parenthesized expression within.
          (?<=\()[^()\r]*\([^()\r]*\)[^()\r]*(?=\))
          Close enough? I don't think it can be adjusted to account for "either/or". In that case you're probably better off just replacing all of the text with italics, and then selectively remove it from just the outermost parentheses.
          • 2. Re: find between brackets
            dhafirp16891848 Level 1
            Hi gert verrept,
            Try this by one click:
            • 3. Re: find between brackets
              Obi-wan Kenobi Level 5
              Jongware's way works only in one case: double-parenthesis between parenthesis.
              Dhafir's one only catches the text not the parenthesis.
              This one uses the Grep recursive code Gert indicates us [ ]. To do what he wants to get [in all situations], just play 2 regex [+ 3rd optional]:
