7 Replies Latest reply on Jun 5, 2017 11:59 AM by hoa90519171
    How can i add a Tab Stop in a cell by insertionPoint?
    hoa90519171 Level 1
      Hi, All:
      I have a problem,
      There is a table.
      There are a number of cells in the table.
      There are a number of text paragraphs in the cell.
      I need to add a tab stop somewhere in the text paragraph.
      and so:
      I want to get X point for the New Tab Stop.
      My approach is as follows:
      1. Move the insertion point to the target position.
      2. Obtain the insertion point of the X point.
      This is my code to get the X point from insertion point:
      var myIP = app.selection[0]
      $.writeln(getRelativeX(myIP))
      function getRelativeX(myIP){
       var myPG = myIP.paragraphs[0]
       if(myPG.justification != Justification.LEFT_ALIGN){
            var scriptString = 'myPG.justification = Justification.LEFT_ALIGN';
            var test = app.doScript(scriptString, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "getRelativeX");
            var myPGZeroPoint = myPG.horizontalOffset - myPG.leftIndent - myPG.firstLineIndent
            app.activeDocument.undo()
       }else{
       var myRelativeX = myIP.horizontalOffset - myPGZeroPoint
       return myRelativeX
      If the paragraph's alignment is not on the left will get the wrong answer.
      So I change the alignment on the left and then undo.
      Is there a better way? with out undo?
      Thx a lot.
        • 1. Re: How can i add a Tab Stop in a cell by insertionPoint?
          Trevorׅ Adobe Community Professional
          Hi Hoa,
          One option would be to just use the properties
          IN PSEUDO CODE!
          var currentJust = myPG.justification;
          if !LTR {
          set to LTR
          do the calculation
          reset myPG.justification = currentJust
          However it might be better to use the undo method but with the UndoModes.AUTO_UNDO and no tag so that the undo doesn't show up on the edit history.
          I somehow also feel there might well be a better way of doing it. But I can see problems with them in cases like tables.
          HTH
          Trevor
          • 2. Re: How can i add a Tab Stop in a cell by insertionPoint?
            hoa90519171 Level 1
            Hi Trevor,
            Thanks for your reply.
            I agree with you, change the properties will be better than use UNDO.
            However, it seems to be no difference in nature.
            Is it possible to get results in a calculated way?
            • 3. Re: How can i add a Tab Stop in a cell by insertionPoint?
              If you are working with simple non transformed text frames then you can just add to the geometricBounds.
              If your dealing with tables then your have to calculate the starts of the cell.
              • 4. Re: How can i add a Tab Stop in a cell by insertionPoint?
                The fact is that the current method you are using is not going to deal with transformations.
                • 5. Re: How can i add a Tab Stop in a cell by insertionPoint?
                  hoa90519171 Level 1
                  Do you mean we had a (better / correct) way to (get cell zero point / add a tab stop at insertion point)?
                  • 6. Re: How can i add a Tab Stop in a cell by insertionPoint?
                    This is the sort of getter / setter I had in mind.
                    function getTabStop(tabStopProperties, applyToParagraphStyle) {
                        var selection, tf, ipOffset, p, tabProperties, ip, tabListLength;
                        selection = app.selection[0];
                        if (!selection) {
                            return 'No Selection';
                        if (!selection.properties.baseline) {
                            return 'Selection is not a text object';
                        if (selection.parent.constructor !== Story) {
                            return 'Sorry only simple text frames currently supported (No tables)';
                        tf = selection.parentTextFrames[0];
                        if (tf.constructor !== TextFrame) {
                            return 'Sorry only simple text frames currently supported (No paths)';
                        // Not dealing with character rotation or textFrame transformation
                        // Will do so in exchange for payment
                        ip = selection.insertionPoints[0];
                        bound = ip.paragraphs[0].paragraphDirection === ParagraphDirectionOptions.LEFT_TO_RIGHT_DIRECTION ? 1 : 3;
                        ipOffset = Math.abs(tf.geometricBounds[bound] - ip.horizontalOffset);
                        if (!tabStopProperties) {
                            return ipOffset;
                        tabProperties = {
                            alignment: TabStopAlignment.LEFT_ALIGN,
                            alignmentCharacter: ".",
                            leader: "",
                            position: ipOffset
                        if (tabStopProperties.alignment) {
                            tabProperties.alignment = tabStopProperties.alignment;
                        if (tabStopProperties.alignmentCharacter) {
                            tabProperties.alignmentCharacter = tabStopProperties.alignmentCharacter;
                        if (tabStopProperties.leader) {
                            tabProperties.leader = tabStopProperties.leader;
                        p = applyToParagraphStyle ? ip.appliedParagraphStyle : ip.paragraphs[0];
                        tabListLength = p.tabList.length;
                        p.tabStops.add(tabProperties);
                        if (tabListLength === p.tabList.length) {
                            // Basic paragraph style - couldn't add tab spot to style so add it to paragraph
                            // This will also get set if the tab position already exists
                            ip.paragraphs[0].tabStops.add(tabProperties);
                        return ipOffset;
                    function setTabStop(tabStopProperties, applyToParagraphStyle) {
                        return getTabStop(tabStopProperties || true, applyToParagraphStyle);
                    alert('get position: ' + getTabStop());
                    //alert(setTabStop());
                    var props = {
                        leader: "."
                    alert('set position: ' + setTabStop(props, true));
                    HTH
                    Trevor
                    • 7. Re: How can i add a Tab Stop in a cell by insertionPoint?
                      hoa90519171 Level 1
                      This is good, but with the table or in other special positions is the main part of the problem I have yet to.
