1 Reply Latest reply on May 30, 2017 2:31 AM by Cleo_helm
    Can't connect to InDesign in ExtendScript Toolkit
    Cleo_helm
      Hello,
      I'm trying to write Scripts in ExtendScript for Adobe InDesign.
      I read the thread about the lack of a program to choose in ExtendScript (from 2013). I have Adobe InDesign in the list, but it doesn't open or makes connection when I choose it. It also doesn't connect when I have InDesign already open.
      When I open InDesign manually I have to say as admin to allow InDesign to open, this I can't change, is this an issue for ExtendToolkit, is there any workaround?
      It is anoying to copy every change in a script to the correct folder and than run it in InDesign where I can't see why something is not working.
      Thank you for help
      Cleo
      I made this Bridge Diagnosis (BridgeTalk.__diagnostics__;) thing and this is the result:
      Ergebnis: BridgeTalk Diagnostics
          Info:
              Name = estoolkit-3.8
              Status = PUMPING
              Group = cs
              Path = C:\Program Files (x86)\Adobe\Adobe Utilities - CS6\ExtendScript Toolkit CS6\ExtendScript Toolkit.exe
              Version = 2.0
              Build = ES 4.2.12
              Next serial number = 67
              Logging: = OFF
              Now = 09:51:00
                  Message Version = 2.05
                  Authentication = ON
                  Digest = ON
          Thread: estoolkit-3.8#thread
              Avg. pump interval = 30ms
              Last pump = 38ms ago
              Ping: 7
                  ECHO_REQUEST: ECHO_RESPONSE
                      Timeout = undefined
                      Handler = undefined
                  STATUS: PUMPING
                      Timeout = undefined
                      Handler = undefined
                  MAIN: MAIN
                      Timeout = undefined
                      Handler = installed
                  LAUNCHED: LAUNCHED
                      Timeout = undefined
                      Handler = installed
                  DIAGNOSTICS: DIAGNOSTICS
                      Timeout = undefined
                      Handler = installed
                  INFO: INFO
                      Timeout = undefined
                      Handler = installed
                  SETUPTIME: thread=1ms, left=68ms
                      Timeout = undefined
                      Handler = undefined
          Instances: 3
              estoolkit-3.8#dbg:
                      msg[09:51:00]: 00000062
                          @BT>Version = 2.05
                          Target = estoolkit-3.8#dbg
                          Sender = estoolkit-3.8#dbg
                          Sender-ID = localhost:win6332
                          Timeout = 09:51:01
                          Type = Ignore
                          Response-Request = Timeout
                          Headers = (no headers)
                          Timestamp = 09:51:00
                          Serial-Number = 62
                          Received = undefined
                          Result = undefined
                          Error = undefined
                          Body = (empty)
                  Incoming: 1
                  Outgoing: 0
                  Handler: 9
                      ExtendScript = for all messages
                      Error = for only msg #25
                      Error = for only msg #27
                      Error = for only msg #34
                      Result = for only msg #62
                      Error = for only msg #62
                      Timeout = for only msg #62
                      Result = for only msg #64
                      Error = for only msg #64
              estoolkit-3.8#estk:
                      msg[09:51:00]: 00000064
                          @BT>Version = 2.05
                          Target = estoolkit-3.8#estk
                          Timeout = 10:01:00
                          Type = Debug
                          Response-Request = Result Error
                          Serial-Number = 64
                          Result = undefined
                          Error = undefined
                          Body: 107 bytes
                              Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                  Incoming: 1
                  Outgoing: 0
                  Handler: 1
              estoolkit-3.8: (main)
                  Incoming: 0
                  Outgoing: 0
                  Handler: 1
          Targets: 11
              Connector = PCD
              Installed: 0
              Running: 0
                  ame-6.0:
                      Group = cs
                      Path = C:\Program Files\Adobe\Adobe Media Encoder CS6\Adobe Media Encoder.exe
                      Display Name = Adobe Media Encoder
                      MsgAuthentication = ON
                      MsgDigest = ON
                      ESTK = ON
                      Status = (not running)
                      ExeName = Adobe Media Encoder.exe
                  bridge-5.032:
                      Group = cs
                      Path = C:\Program Files (x86)\Adobe\Adobe Bridge CS6\Bridge.exe
                      Display Name = Bridge CS6
                      MsgDigest = ON
                      ESTK = ON
                      ExeName = Bridge.exe
                  bridge-5.064:
                      Group = cs
                      Path = C:\Program Files\Adobe\Adobe Bridge CS6 (64 Bit)\Bridge.exe
                      Display Name = Bridge CS6 (64 bit)
                      MsgDigest = ON
                      ESTK = ON
                  estoolkit-3.8: PUMPING
                      Group = cs
                      Display Name = ExtendScript Toolkit CS6
                      MsgDigest = ON
                      ESTK = ON
                      Status = PUMPING
                      Info:
                          Group = cs
                          Version = 2.0
                          Build = ES 4.2.12
                          Next serial number = 73
                          Logging: = OFF
                          Now = 09:51:00
                              Authentication = ON
                              Digest = ON
                          Last pump = 238ms ago
                          Ping: 7
                                  Timeout = undefined
                                  Handler = undefined
                              STATUS: PUMPING
                                  Timeout = undefined
                                  Handler = undefined
                              MAIN: MAIN
                                  Timeout = undefined
                                  Handler = installed
                              LAUNCHED: LAUNCHED
                                  Timeout = undefined
                                  Handler = installed
                                  Timeout = undefined
                                  Handler = installed
                              INFO: INFO
                                  Timeout = undefined
                                  Handler = installed
                                  Timeout = undefined
                                  Handler = undefined
                      ExeName = ExtendScript Toolkit.exe
                  exman-6.0:
                      Group = cs
                      Path = C:\Program Files (x86)\Adobe\Adobe Extension Manager CS6\Adobe Extension Manager CS6.exe
                      Display Name = Adobe Extension Manager CS6
                      MsgDigest = ON
                      ESTK = OFF
                      BundleID = com.adobe.exman
                      ExeName = Adobe Extension Manager CS6.exe
                  illustrator-16.032:
                      Group = cs
                      Path = C:\Program Files (x86)\Adobe\Adobe Illustrator CS6\Support Files\Contents\Windows\Illustrator.exe
                      Display Name = Adobe Illustrator CS6
                      MsgDigest = ON
                      ESTK = ON
                      ExeName = Illustrator.exe
                  illustrator-16.064:
                      Group = cs
                      Path = C:\Program Files\Adobe\Adobe Illustrator CS6 (64 Bit)\Support Files\Contents\Windows\Illustrator.exe
                      Display Name = Adobe Illustrator CS6 (64 bit)
                      MsgDigest = ON
                      ESTK = ON
                  indesign-8.0:
                      Group = cs
                      Path = C:\Program Files (x86)\Adobe\Adobe InDesign CS6\InDesign.exe
                      Display Name = Adobe InDesign CS6
                      MsgDigest = ON
                      ESTK = ON
                      ExeName = InDesign.exe
                  photoshop-60.032:
                      Group = cs
                      Path = C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Photoshop.exe
                      Display Name = Adobe Photoshop CS6
                      MsgDigest = ON
                      ESTK = ON
                      BundleID = com.adobe.Photoshop
                      ExeName = Photoshop.exe
                  photoshop-60.064:
                      Group = cs
                      Path = C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Photoshop.exe
                      Display Name = Adobe Photoshop CS6 (64 bit)
                      MsgDigest = ON
                      ESTK = ON
                  switchboard-2.0:
                      Group = cs
                      Path = C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
                      Display Name = SwitchBoard 2.0
                      MsgDigest = ON
                      ESTK = OFF
                      ExeName = SwitchBoard.exe
              Installed: 10
              Running: 1
              Groups: 119
                  cs3:
                      acrobat-8.0
                      aftereffects-8.0
                      soundbooth-1.0
                      bridge-2.0
                      contribute-4.5
                      devicecentral-1.0
                      dreamweaver-9.0
                      encore-3.0
                      estoolkit-2.0
                      fireworks-9.0
                      flash-9.0
                      illustrator-13.0
                      indesign-5.0
                      indesignserver-5.0
                      incopy-5.0
                      photoshop-10.0
                      premiere-3.0
                      stockphotos-1.5
                      audition-3.0
                  cs4:
                      acrobat-9.0
                      aftereffects-9.0
                      soundbooth-2.0
                      bridge-3.0
                      contribute-5.0
                      devicecentral-2.0
                      dreamweaver-10.0
                      encore-4.0
                      estoolkit-3.0
                      fireworks-10.0
                      flash-10.0
                      illustrator-14.0
                      indesign-6.0
                      indesignserver-6.0
                      incopy-6.0
                      photoshop-11.*
                      premierepro-4.0
                      audition-4.0
                      ame-1.0
                      exman-2.0
                  cs5:
                      acrobat-9.0
                      aftereffects-10.0
                      soundbooth-3.0
                      bridge-4.0
                      contribute-6.0
                      devicecentral-3.0
                      dreamweaver-11.0
                      encore-5.0
                      estoolkit-3.5
                      fireworks-11.0
                      flash-11.0
                      illustrator-15.0
                      indesign-7.0
                      indesignserver-7.0
                      incopy-7.0
                      photoshop-12.*
                      premierepro-5.0
                      audition-5.0
                      ame-2.0
                      exman-3.0
                      flashbuilder-4.0
                      flashcatalyst-1.0
                  ts1:
                      captivate3-en_us
                      captivate3-fr_fr
                      captivate3-it_it
                      captivate3-ja_jp
                      captivate3-es_es
                      captivate3-de_de
                  ts2:
                      captivate-4.0
                  el2:
                      captivate-5.0
                  as1:
                      acrobat-10.0
                  ts3:
                      robohelp-9.0
                      framemaker-10.0
                  cs55:
                      aftereffects-10.5
                      audition-4.0
                      bridge-4.1
                      contribute-6.1
                      devicecentral-3.5
                      dreamweaver-11.5
                      encore-5.1
                      estoolkit-3.6
                      fireworks-11.1
                      flash-11.5
                      illustrator-15.1
                      indesign-7.5
                      indesignserver-7.5
                      incopy-7.5
                      photoshop-55.*
                      premierepro-5.5
                      ame-2.5
                      exman-5.5
                      flashbuilder-4.5
                      flashcatalyst-1.5
                      switchboard-2.0
                  el25:
                      captivate-5.5
                  cs60:
                      aftereffects-11.0
                      audition-5.0
                      bridge-5.*
                      contribute-6.88
                      devicecentral-4.0
                      dreamweaver-12.0
                      encore-6.0
                      estoolkit-3.8
                      fireworks-12.0
                      flash-12.0
                      illustrator-16.*
                      indesign-8.0
                      indesignserver-8.0
                      incopy-8.0
                      photoshop-60.*
                      premierepro-6.0
                      ame-6.0
                      exman-6.0
                      flashbuilder-4.52
                      switchboard-2.0
                      prelude-1.0
                      speedgrade-6.0
                  el60:
                      captivate-60.*
                  ts4:
                      robohelp-10.0
                      framemaker-11.0
