7 Replies Latest reply on Jun 27, 2017 5:02 PM by Kevin-Monahan
    Problem aligning camera movement between AE and C4D
    davidc56699872
      I tried exporting a camera from AE to C4D and imported the file with my 3D object back into after effects. I made sure the comp size and frame rate match.
      Somehow, the 3d object I put in the comp is "traveling" horizontally and does not stick to a point on the ground.
      When this didn't work, I tried tracking the entire comp with the 3d tracker and then added the 3d object back into the scene and the problem remained. What am I doing wrong?
      The landscape was made using GeoLayers and MIR - perhaps this is a part of the issue? although when I tracked it in a precomp with a 3d tracker my logic tells me After Effects should analyze it the same way it analyzes any video file.
      Here is a video of the problem:
      3D Landscape RENDER - Vidme
      Thanks!
