Can some one please help.
I have created a template with my logo and would like to use it on multiple images and print them to file.
I can do one at a time but can i do more. I want a single image per page and I have over 100 images that need the template. Surely there is a way.
Please please help
Thank you
Gary
Using "Custom Package"- Correct - It does not work as you want.
Custom package implies that you manually select images to place in (multiple) cells on the page.
You say "I want a single image per page"- In that case design a template using the "Single Image/Contact Sheet" Layout option, then the images will auto-print (to files) the whole batch.
You have lots of options to set cell size and location of the image on paper with "Single Image/Contact Sheet" Layout.
Select the 100 images (either in Grid mode or the Print module filmstrip)
In the Print module-
Choose your template, recheck your page Setup as defined in the template,
Check that you have the option to print "Selected Photos"
Click [Print]. Done! Keep your printer fed with paper
You will notice that Lr will show Page 1 of 100 (or whatever you selected) just below the photo panel-
And it might be a good idea (before you [Print] ) to click on the first photo in the filmstrip and cursor along to visually check each photo will print OK.
Thanks for your response.
I am using a custom page and want to print to file.
I have tried your idea but it did not work.
