• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to save separate files from one document with unique name on each other?
Community Beginner ,
May 30, 2017 May 30, 2017
Hi to Everyone,
I need to save 30 different pages as separately pdfs with a unique name on each other. Is there any possibility to make it automatically?
I already installed Page Exporter Utility but as I see (or maybe I missed) there is no function to name each file as a paragraph or something.
Same with a book, even if the file name is unique you can't save it with a unique name as separate pdf automatically. Or maybe there is some script which can export a batch of files to PDF like in Image Processor in Photoshop? It will be a great time saver if something like this exists! Maybe someone had the same problem?
Views
7.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Votes
Translate
Translate
Report
Report
Thanks for your answer amaarora  but, the idea to have unique names and don't rename them manually.
For example:
bird.pdf
fox.pdf
fish.pdf
etc
any ideas?=)
Votes
Translate
Translate
Report
Report
Community Expert ,
What you can do is Bookmark some text in your InDesign file.
Make sure include bookmarks is ticked
Acrobat will show the bookmarks
Go to the Split function in Acrobat
And choose Top Level Bookmarks
Go to the options and select "Use Bookmark names for file names"
It should then spit out the pages.
It seems like a long process however
1) Select text in the InDesign layout and click the New button on the Dialog box to create a bookmark
2) Export to PDF
3) Split>top level bookmarks>by bookmark name
It's a one time setup and can be changed easily.
Plus any future changes to the document you can add bookmarks as you see fit.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Looks perfect!
-Aman
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Aman,
I see one issue with the Acrobat workflow:
After splitting the document the individual pages will not pass as PDF/X with preflight if you exported the multipage document to PDF/X from InDesign. Did not test that with Acrobat Pro DC, but I remember the problem from previous versions.
Another step would be needed for the split documents:
Acrobat: Batch preflight the PDFs and convert to PDF/X.
Unique names could be done by a UUID generator.
For example: Online UUID Generator Tool
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Community Expert ,
May 31, 2017 May 31, 2017
That's weird! You'd think that the PDFs would remain the same as  you output as... weird!
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi Eugene,
technically they are.
Did not test this with Acrobat DC.
I'm not sure, but:
The first page should still be a PDF/X.
All others are missing the tag entries that identify them as PDF/X.
The entries are not stored per page but per document.
By using Acrobat's preflight functionality you can correct this ( if you know what you do ) 🙂
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Thank you, Eugene! It is Perfectly working!
In the end, I just adding then my main text in Bridge with the batch tool. And it looks like this:
BOOK_bird.pdf
BOOK_fox.pdf
BOOK_fish.pdf
Many Thanks again! EugeneTyson​
Votes
Translate
Translate
Report
Report
New Here ,
Dec 09, 2020 Dec 09, 2020
LATEST
Hi there,
I need to do the same here but i have near to 200 documents that i need to split and rename as unique characters. I see you would to create bookmarks and save as bookmark names, does this mean i need to create near to 200 bookmarks?
Nicola
Votes
Translate
Translate
Report
Report
