I'm trying to create a script to save a folder full of FM files to TEXT.
My script is running fine until I get to file.Save() and I get a 'file.Save is not a function' error. Can someone help understand where this has gone wrong? Thank you.
var selectedFolder = Folder.selectDialog ("Select Folder with Source Files");
if(selectedFolder != null){
myFolder = new Folder(selectedFolder);
var myFiles = myFolder.getFiles("*.fm");
}else{
alert('Could not access that folder');
if(myFiles.length > 0){
listFiles(myFiles);
}else{
alert('No FrameMaker files found in this folder');
function listFiles(selectedFiles){
for(var i = 0; i< selectedFiles.length; i++){
saveAsText(selectedFiles);
return true;
//~ https://forums.adobe.com/thread/1819414
function saveAsText (file) {
// Replace the hash and file extension
var newName = file.absoluteURI.replace (/\.[\S\.^\.\\]+$/,".txt");
// Get required parameters for the save function.
var params = GetSaveDefaultParams();
var returnParamsp = new PropVals();
var saveName = file.rename(newName);
if(file.error ){
alert( "ERROR:" + file.error + " FILE:" + newName);
var i = GetPropIndex(params, Constants.FS_FileType);
params.propVal.ival = Constants.FV_SaveFmtText;
// Save the document as TXT.
file.Save(saveName, params, returnParamsp);
return true;
What are you passing as the filename argument to the getDocument function? If you have a file object, you should pass the fsName property, which is the platform-specific, absolute path to the file.
Here is a function that I have that works:
function saveToText (doc) {
var params, returnParams, saveName, i;
saveName = doc.Name.replace(/\.fm$/i, ".txt");
returnParams = new PropVals();
i = GetPropIndex (params, Constants.FS_FileType);
i = GetPropIndex (params, Constants.FS_SaveTextTblSetting);
params.propVal.ival = Constants.FV_SaveTblUserPref;
doc.Save (saveName, params, returnParams);
PrintSaveStatus (returnParams);
As I look at your code, the problem is that you need to open each document in FrameMaker in order to save it. The Save method is valid on a Doc object and the only way to get a Doc object is to open the file with FrameMaker.
Do you mean physically open the file in Frame and then run the script?
Or do I use something like
var myFile = new File(selectedFiles);
myFile.open();
saveAsText(myFile);
myFile.close();
return true;
inside of my listFiles function?
Just to clarify: you need to open the files in FrameMaker, but of course you can do it programmatically, not manually in the interface. Here are a set of functions to open a FrameMaker document. You call the getDocument function, passing it the platform-specific full path to the file.
function getDocument (filename) {
// See if the document is already open.
var doc = docIsOpen (filename);
if (doc) {
return doc;
} else {
// The document is not already open, so open it.
return openDocOrBook (filename, undefined, false);
function docIsOpen (filename) {
// Make a File object from the file name.
var file = File (filename);
// Uppercase the filename for easy comparison.
var name = file.fullName.toUpperCase ();
// Loop through the open documents in the session.
var doc = app.FirstOpenDoc;
while (doc.ObjectValid () === 1) {
// Compare the document’s name with the one we are looking for.
if (File (doc.Name).fullName.toUpperCase () === name) {
// The document we are looking for is open.
doc.openedByScript = false;
return doc;
doc = doc.NextOpenDocInSession;
function openDocOrBook (filename, structuredApplication, visible) {
var i = 0, docOrBook = 0;
// Get default property list for opening documents.
var openProps = GetOpenDefaultParams ();
// Get a property list to return any error messages.
var retParm = new PropVals ();
// Set specific open property values to open the document.
i=GetPropIndex (openProps,Constants.FS_AlertUserAboutFailure);
openProps.propVal.ival=false;
i=GetPropIndex (openProps,Constants.FS_MakeVisible);
openProps.propVal.ival=visible;
i=GetPropIndex (openProps,Constants.FS_FileIsOldVersion);
openProps.propVal.ival=Constants.FV_DoOK;
i=GetPropIndex (openProps,Constants.FS_FileIsInUse);
openProps.propVal.ival=Constants.FV_ResetLockAndContinue;
i=GetPropIndex (openProps,Constants.FS_FontChangedMetric);
i=GetPropIndex (openProps,Constants.FS_FontNotFoundInCatalog);
i=GetPropIndex (openProps,Constants.FS_FontNotFoundInDoc);
i=GetPropIndex (openProps,Constants.FS_RefFileNotFound);
openProps.propVal.ival=Constants.FV_AllowAllRefFilesUnFindable;
if (structuredApplication !== undefined) {
i=GetPropIndex (openProps,Constants.FS_StructuredOpenApplication);
openProps.propVal.sval=structuredApplication;
// Attempt to open the document.
docOrBook = Open (filename,openProps,retParm);
if (docOrBook.ObjectValid () === 1) {
// Add a property to the document or book, indicating that the script opened it.
docOrBook.openedByScript = true;
else {
// If the document can't be open, print the errors to the Console.
PrintOpenStatus (retParm);
return docOrBook; // Return the document or book object.
Thanks so much for all of the help.
Now however, in openDocOrBook() Open() is returning an invalidobject and PrintOpenStatus is telling me FV_BadFileName (specified filename was invalid) in the FM console. Do you know what could be causing this?
Ding ding! We have a winner. Thank you so much!
My pleasure!
