1 Reply Latest reply on Sep 3, 2016 12:05 PM by ranjansingh
    Creating a Constraint
    ishitaa25076879
      Hi Guys,
      Can you guide me to the process of creating a constraint which allows to restrict keywords bids to a specified range?
        • 1. Re: Creating a Constraint
          ranjansingh Adobe Employee
          Hi Ishita,
          For creating constraint, you can first create label through Labels tab.
          • Once labels have been defined, they can be now being constrained: From the Labels tab >> there is label’s settings dialog box >>you find below three sections in the edit constraint box
            • Basic: Set the constraint’s currency, status, priority, and choose the constraint type.
              • There are several different kinds of constraint actions to choose.
            • Conditions: Instruct the system to apply a constraint only if specific conditions are met (based on cost and/or revenue metrics) for a bid unit.
            • Run period: Specify a start and end date for the constraint.
          Fill all info as per your requirements and then SAVE it.
          Hope It helps.
          Regards,
          Ranjan
