1 Reply Latest reply on Aug 25, 2016 3:49 AM by nidhik
    Changing Global Date Filter
    akankshag13234296 Level 1
      Can anyone tell me the steps to change the global date filter in search portfolio view? I am unable to do it somehow.
        • 1. Re: Changing Global Date Filter
          nidhik Level 3
          Hi Akanksha,
          On Portfolio view, click on the current date range on top right of the table, you can select the date range from the options in the list or specify the range be selecting the custom date range option, dates should be entered in the following format 'MM/DD/YYYY', also to compare the data with other date range , you can select a check box next to 'compare with' and click apply.
          Hope this helps.
          Regards
          Nidhi
