2 Replies Latest reply: Oct 9, 2008 7:15 PM by Newsgroup_User RSS
    WaitForNetConnection
    Newsgroup_User Community Member
      Movie A is waiting for net connections
      Movie B tries to connect to Movie A
      Movie A decides not to accept the connection (bad password, banned
      userID, etc) so it's WaitForNetConnection handler returns False instead
      of True.
      From what I can tell, no message is sent to Movie B, it justs seems to
      sit idle waiting for an answer. Is this correct?
      I would like Movie B to inform the user that the connection was rejected
      and why. The only way I can think of doing it is for Movie A to actually
      accept the connection request, send a message that the password was bad,
      then have Movie A break the connection.
      Is there a better way?
        • 1. Re: WaitForNetConnection
          > of True.
          Normally, movie's B muXtra should reply with a message containing an
          errorcode.
          Try to connect to movie A using this movie:
          http://goMU.rebus.gr/Examples/Connections/goMU-connect.dir
          and see if you get an error message
          I'd recommend using custom authentication code: allow all users to
          connect, no matter the id, and then ask them to provide their true
          id/pass. You can then allow them to continue, or disconnect them.
          That way, you can also have a descent registration page, within your movie.
          • 2. Re: WaitForNetConnection
            Doh! I had used setNetMessageHandler to capture the "ConnectionProblem"
            message, but I forgot to actually create the handler! In fact if
            WaitForNetConnection returns FALSE the ConnectionProblem message is sent
            to both movies.
            Of course the error code is the generic -2147216214 error, so if I want
            user to know explicitly why the connection request was rejected, your
            suggestion sounds like the way to go.
