0 Replies Latest reply on Oct 2, 2008 8:49 AM by nhill40
    Anyone working with Xfire?
    nhill40
      Howdy all -
      I am working on a project right now that is using a Flex front end with a Java back end. I sort of inherited this code, but from what I understand it is using xfire to actually communicate back 'n' forth between the Flex and Java.
      What we're trying to do is relatively simple - we have an existing Java class that we are attempting to add a new instance variable to. The instance variable has been added and working just fine within the Java. I have also used xdoclet to re-create the ActionScript value object. The value object seems to be working fine within Flex itself, but when we try to pass data back 'n' forth, this new value always ends up showing up as "null". Is there something from an xfire perspective that needs to be done manually that we are missing?
      Thanks!
