Expand my Community achievements bar.
SOLVED
AEM Site Login
Avatar
Level 5
Do all sites launched on AEM need to be logged into when publicly accessing it or is there a way to turn
this feature off?
1 Accepted Solution
Avatar
Correct answer by
Employee
RamRaja wrote...
Sorry, What I'm trying to do is take the login feature off on a website I've published. Currently when accessing the site on
a tablet or phone it's taking me to the AEM login screen first. I want it to go directly to the site so the public can have access
Hi Ram,
you did not mention what happens when you access the site from a desktop?
AEM by default does not put authentication on a site on the publish instance. Someone must have enabled authentication for your site. Can you check the page properties for your root page. Under the advanced tab, check the closed user group settings. [1]
Also check http://localhost:4503/system/console/configMgr/com.day.cq.auth.impl.LoginSelectorHandler
The following page explains all this [2]
Regards,
Opkar
[1] https://helpx.adobe.com/experience-manager/kb/HowToSetupCUG.html
[2] http://cqhints.blogspot.co.uk/2014/01/login-logout-on-publish-instance-and.html
View solution in original post
Avatar
Employee
Public sites are usually not protected unless you specifically turn on authentication for your content path(site)[1]
By default your author instance does not allow anonymous access, but on the publish instance, anonymous access is allowed for /content where set by your security settings.
Regards,
Opkar
[1] http://cqhints.blogspot.co.uk/2014/01/login-logout-on-publish-instance-and.html
[2] https://helpx.adobe.com/experience-manager/kb/HowToSetupCUG.html
Avatar
Level 10
As Opkar suggested, you can go for Login based [OR] Fully Anonymous [OR] Login + Anonymous. These can be configured.
Avatar
Level 5
Yes I want the site to be fully anonymous. The login I'm talking about turning off is the AEM Welcome Screen.
Can someone direct me how to turn this security feature off?
Avatar
Employee
The welcome screen is only present in the author instance after you login. When your publish instance starts it should take your straight to Geometrix (unless you installed with nosamplecontent)
What URL:port are you accessing?
Regards,
Opkar
Avatar
Level 5
port 4503, I just tried accessing it but it's still redirecting to welcome screen.
Avatar
Employee
You can change the root page that is shown by configuring the Day CQ Root mapping OSGI config
https://docs.adobe.com/docs/en/aem/6-1/deploy/configuring/osgi-configuration-settings.html
Avatar
Level 5
a tablet or phone it's taking me to the AEM login screen first. I want it to go directly to the site so the public can have access.
Thanks!
Avatar
Correct answer by
Employee
RamRaja wrote...
Hi Ram,
Regards,
Opkar
