8 Replies Latest reply on Oct 7, 2008 8:56 AM by g-s-b
    How would you do it
    wkolcz Level 1
      I have an application that takes a login of a username and password. The app consists of a main Application and a number of modules and components. I would like to set the username and have it accessible throughout the application via a 'global' variable. What is the procedure to set it so all the modules and components can access it from the main Application?
      Thanks.
        • 1. Re: How would you do it
          dietmar.paulus Level 1
          Hi
          If you call Application.application you always have access to your main Application, also if you call this out of the modules.
          So if you define a public variable in your main Application you can access this via Application.application.<your variable>.
          cheers
          dietmar
          • 2. Re: How would you do it
            wkolcz Level 1
            Would I have to set it as static?
            So if after login I set:
            private var username:String = "steve"
            I can access it as Application.application.username?
            • 3. Re: How would you do it
              wkolcz Level 1
              public var username:String = "steve"
              • 4. Re: How would you do it
                I think yes you can access it like that, but just try it.
                cheers
                dietmar
                • 5. Re: How would you do it
                  Level 7
                  "projectproofing" <webforumsuser@macromedia.com> wrote in message
                  news:gcfjbq$ae3$1@forums.macromedia.com...
                  >app
                  > would
                  > via
                  > and
                  Look at the Singleton design pattern.
                  • 6. Re: How would you do it
                    g-s-b Level 1
                    If you look at "best practices" I think you will find that "global" data elements like that are not good. Rather one should "get or put" a copy of the data where it is needed: events, bindings, etc.
                    And the "singleton" pattern itself seems "depreciated" these days.
                    These are mostly "design pattern decisions" implemented for "clean code" and "testing."
                    greg
                    • 7. How would you do it
                      wkolcz Level 1
                      Sorry, that answer seems very good, but a little vague. Please explain or send me to an example of how this possible.
                      I am not sure if the Singleton design pattern is needed. I am not worried about multiple instances of a username variable in a single user application.
                      From my understanding is that is good put an instance of an object in a singleton to make it's functions accessible and ensuring only one instance.
                      I am more looking for a static variable that is global.
                      • 8. Re: How would you do it
                        g-s-b Level 1
                        If you must have "global" data elements you must decide on what is your liking.
                        Above Application.pplication.myDataElement will work fine.
                        A Class with data elements as static will also work.
                        And finally, as Amy said, a Singleton Class with public variables will also do.
                        Only one piece of data, user... I would suggest the as dietmar.paulus has, the Application.application public data variable.
                        It should get the job done although it is not pretty.
                        greg
