In general what would be the steps and which customizations should be done to implement a Two-Factor Authenticaction on AEM?
Is there any doc describing this use case?
Solved! Go to Solution.
Views
Total Likes
If you are using saml [1] then it is simple as IDP takes care of everything. In fact that is the standard most common implementation i have seen so far in AEM and is simple also.. in case you are not using saml then need custom authentication handler implementation & no out of the box option available.
[1]
https://helpx.adobe.com/experience-manager/kb/saml-demo.html
http://docs.adobe.com/docs/en/cq/5-6-1/core/administering/saml-2-0-authenticationhandler.html
[1]
