4 Replies Latest reply on Oct 7, 2008 10:42 AM by anna needs help
    preloader not going dissappearing immediately
    anna needs help Level 1
      so my problem is this. when the preloader loads the main movie into the container it doesnt go away immediately. it also messes up something with the list which is supposed to start off being not visible until you push the list of works button. it shows the list right away and then wont let you close it. any advice is greatly appreciated
      thanks,
      anna
      this is where you can see the problem.
      this is how the list is supposed to work.
      it works when it doesnt have a preloader.
      this is the flash main file
      this is the preloader
        • 1. Re: preloader not going dissappearing immediately
          Level 7
          remove the _root from your Visible action.
          You missing the path. The file on its own has correct path, but once you load
          it in movie holder within another level, you share timeline with the main movie
          so your path changes automatically to _level0.container.list_mc._visible....
          That is why the action can't find the target.
          You can remove the _root or change it to _root.container.list_mc._visible=false;
          Best Regards
          Urami
          "Never play Leap-Frog with a Unicorn."
          <urami>
          If you want to mail me - DO NOT LAUGH AT MY ADDRESS
          </urami>
          • 2. Re: preloader not going dissappearing immediately
            it's totally working great (thank you, thank you) except that i can't use the close button in the list of works box to close it. any ideas?
            i have uploaded edited fla files.
            • 3. Re: preloader not going dissappearing immediately
              Ed_Miller
              The close button in the list movie clip does not have any actionscript associated with it. Add on(release) { this._visible = false; } to that button and it should close fine. Also, there's some on(release) code on the list movie clip, which will not work unless it is a button.
              • 4. Re: preloader not going dissappearing immediately
                I am so grateful for all of your help. I am amazed at the community of people out there to help each other. Hopefully, in time I will know enough to help someone also.
