1 Reply Latest reply on Sep 29, 2008 1:19 PM by NightScholar
    Swapping RemoteObject dataprovider on 2 grids
    NightScholar
      I'm at a loss, I've searched through the forums and documentation and the only suggestion to get over this issue is to run the validateNow() on the grid or the parent panel, neither resolve my issue.
      I can assigne the standard datagrid to a hardcoded array, swap that hardcoded array with another and it works fine. The remoteObject swap of dataprovider also works fine. As soon as I change the standard datagrid to a remote object though one of the grids to not repaint/refresh. I've also found that only the second grid will refresh.
      private var dataPool:String = "bamdev";
      [Bindable] private var myArrayCollection:ArrayCollection;
      [Bindable] private var detailTransactionAC:ArrayCollection;
      [Bindable] private var dataGridResponder:DataGridResponder = new DataGridResponder();
      private var vantiveAllSql:String = "SELECT * FROM OAD_VANTIVE_PR_SUM_V";
      private var vantiveACSSql:String = "SELECT * FROM OAD_VANTIVE_PR_SUM_V WHERE APPLICATION_ID IN ('ACS', 'CRM', 'OMS')";
      private var transACSSql:String = "SELECT * FROM OAD_TRANS_TEMP WHERE APPNAME = 'ACS'";
      private function runStatement(stmnt:String,type:String):void
      var token:AsyncToken = remoteObj.getDataObjects(stmnt,dataPool);
      switch (type) {
      case "Vantive":
      dataGridResponder.resultHandler = handleResponderResult;
      break;
      case "DetailTransaction":
      dataGridResponder.resultHandler = handleResponderResultDetailTransaction;
      break;
      default:
      //currentState = "AppDetail_State";
      //runStatement(vantiveACSSql);
      //Alert.show("vantiveACSSql was run.");
      break;
      dataGridResponder.faultHandler = handleResponderFault;
      // Now we pass the responder to the token that will call the responder functions when the call to the
      // RemoteObject is finished running the RPC
      token.addResponder(dataGridResponder);
      private function handleResponderResult(ev:ResultEvent):void
      myArrayCollection = ev.result.resultset as ArrayCollection;
      if (myArrayCollection.length== 0)
      vantive_adg.dataProvider = vantiveBlankAC;
      else
      var g:Grouping = new Grouping();
      g.fields = [new GroupingField("APP_TOTAL")];
      var gc:GroupingCollection = new GroupingCollection();
      gc.source = myArrayCollection;
      gc.grouping = g;
      gc.refresh();
      vantive_adg.dataProvider = gc;
      private function handleResponderResultDetailTransaction(ev:ResultEvent):void
      detailTransactionAC = ev.result.resultset as ArrayCollection;
      if (detailTransactionAC.length== 0)
      detail_Transactions_dtg.dataProvider = detailTransactionBlankAC;
      else
      detail_Transactions_dtg.dataProvider = detailTransactionAC;
      private function handleResponderFault(ev:FaultEvent):void
      Alert.show(ev.fault.getStackTrace(), "ERROR in ExampleRemoteObjectUse.handleResponderFault");
      public function onCreationComplete():void
      runStatement(vantiveAllSql,"Vantive");
      private function toggleAppDetail():void
      switch (application_cb.selectedIndex) {
      case 0:
      detail_Transactions_dtg.dataProvider=detailTransactionBlankAC
      //detail_Transactions_dtg.validateNow();
      //DetailTransaction_pnl.validateNow();
      //vantive_adg.validateNow();
      //SummVantive_pnl.validateNow()
      break;
      case 1:
      runStatement(vantiveACSSql,"Vantive");
      runStatement(transACSSql,"DetailTransaction");
      //detail_Transactions_dtg.dataProvider=appLocalTransactionAC
      break;
      [Bindable]
      public var vantiveBlankAC:ArrayCollection = new ArrayCollection([
      {APP_TOTAL:"No Data Available(0)", VANTIVE_NUM:"0", APPLICATION_ID:"No Data Available", VAN_NUM_URL:"about:blank",LAST_UPDATE:"N/A", TEMP:"No Data Available(0)"} ]);
      [Bindable]
      public var detailTransactionBlankAC:ArrayCollection = new ArrayCollection([
      {TRANSNAME:"No Data Returned",last_update: "N/A", AVERSPTM:"N/A", AVERSPTMHEALTH:"0", COUNT:"N/A", COUNTHEALTH:"0"}, ]);
      [Bindable]
      public var appLocalTransactionAC:ArrayCollection = new ArrayCollection([
      {TRANSNAME:"Transaction Summary", AVERSPTM:"157", AVERSPTMHEALTH:"3", COUNT:"527", COUNTHEALTH:"3"},
      {TRANSNAME:"IN-Check Compatibility And Set Product", AVERSPTM:"121", AVERSPTMHEALTH:"4", COUNT:"527", COUNTHEALTH:"5"},
      {TRANSNAME:"IN-Check Eligibility Rules", AVERSPTM:"90", AVERSPTMHEALTH:"4", COUNT:"115", COUNTHEALTH:"3"},
      {TRANSNAME:"IN-Create Interaction", AVERSPTM:"151", AVERSPTMHEALTH:"2", COUNT:"215", COUNTHEALTH:"4"},
      {TRANSNAME:"IN-Create Customer", AVERSPTM:"121", AVERSPTMHEALTH:"4", COUNT:"42", COUNTHEALTH:"2"},
      {TRANSNAME:"IN-Get Negotiated Products", AVERSPTM:"90", AVERSPTMHEALTH:"5", COUNT:"527", COUNTHEALTH:"5"},
      {TRANSNAME:"IN-Get Negotiated Assigned Product", AVERSPTM:"151", AVERSPTMHEALTH:"3", COUNT:"412", COUNTHEALTH:"4"},
      {TRANSNAME:"IN-Get Quote", AVERSPTM:"121", AVERSPTMHEALTH:"4", COUNT:"187", COUNTHEALTH:"2"},
      {TRANSNAME:"IN-Get Available Appointments", AVERSPTM:"90", AVERSPTMHEALTH:"5", COUNT:"10", COUNTHEALTH:"1"},
      {TRANSNAME:"IN-Get Customer Details", AVERSPTM:"151", AVERSPTMHEALTH:"3", COUNT:"127", COUNTHEALTH:"3"},
      {TRANSNAME:"IN-Submit Order Action", AVERSPTM:"121", AVERSPTMHEALTH:"2", COUNT:"112", COUNTHEALTH:"3"},
      {TRANSNAME:"IN-Search Customer", AVERSPTM:"90", AVERSPTMHEALTH:"4", COUNT:"127", COUNTHEALTH:"2"},
      {TRANSNAME:"IN-Update Customer", AVERSPTM:"90", AVERSPTMHEALTH:"5", COUNT:"22", COUNTHEALTH:"3"}
      </mx:Script>
