2 Replies Latest reply on Jul 9, 2013 5:19 AM by support & learning
    Null reference error in axis renderer when redrawing chart
    dah328
      I have a charting application that allows a user to manipulate the underlying dataset and have the chart redrawn at will. I am recreating the chart series, axes, and axis renderers on the fly and reapplying them to the chart in my application. I have recently started getting a null object reference in the AxisRenderer.updateDisplayList() method on line 1128. It seems that the AxisRenderer object is in a weird state because its reference to its parent chart is null. I do not know how that could be the case unless I am doing something wrong in my programmatic creation of my charts axes and axis renderers. Currently, I am doing something similar to this:
      var colSeries : ColumnSeries = new ColumnSeries():
      var axis : LinearAxis = new LinearAxis();
      // create axis renderer
      var ar1 : AxisRenderer = new AxisRenderer();
      ar1.placement = "left";
      ar1.axis = axis;
      colSeries.verticalAxis = axis;
      var seriesAr : Array = { colSeries };
      chart.series = seriesAr;
      chart.verticalAxisRenderer = ar1;
      Is there anything I am leaving out. I tried setting the parent property on the AxisRenderer instance but it is a readonly property.
      Dan
        • 1. Re: Null reference error in axis renderer when redrawing chart
          Cr99 Level 1
          I'm getting this same error when I try to reuse an AxisRenderer or for that matter when I try to reuse a chart. The app needs to run 24/7 and so I need to keep the app from bloating and using so much memory because if I just let it run normally it eventually crashes because AIR never seems to garbage collect the unused components after I remove all the children from the container and redraw the fresh chart.
          Here's a few snippets to show what I'm doing.  It works fine the first time through but after that it crashes giving me this error:
          TypeError: Error #1009: Cannot access a property or method of a null object reference.
          at mx.charts::AxisRenderer/updateDisplayList()[C:\Work\flex\dmv_automation\projects\datavisu alisation\src\mx\charts\AxisRenderer.as:1128]
          (by the way, here is the relavant code from AxisRenderer line 1128 where the error is occurring)
          var chart:ChartBase = this.chart;
          if (_bGuttersAdjusted == true &&
                      chart.chartState != ChartState.PREPARING_TO_HIDE_DATA &&
                      chart.chartState != ChartState.HIDING_DATA)
          so it seems like reference to chart is getting set to null somehow, though I have no idea about the inner workings of AxisRenderer which could be causing this
          // here's some samples from my code
          var genericChart:CartesianChart = getCartesianChart();
          var renderers:ArrayCollection = new ArrayCollection();
          // horizontal axis
          var ar:AxisRenderer = getAxisRenderer();
          var hAxis:DateTimeAxis = getDateTimeAxis();
          ar.axis = hAxis;
          ar.setStyle("canDropLabels", "true");
          genericChart.horizontalAxisRenderers = [ar];
          genericChart.horizontalAxis = hAxis;
          // vertical axis
          var vAxis:LinearAxis = getLinearAxis();
          vAxis.baseAtZero = false;
          var axr:AxisRenderer = getAxisRenderer();
          axr.axis = vAxis;
          axr.setStyle("canDropLabels", "true");
          // -- code which follows (not shown) adds series, stokes, and other visual elements ...
          genericChart.verticalAxisRenderers = renderers.toArray();
          // related function gets a renderer from pool rather than making a new
          // renderer each time to try to conserve memory
          // the index rendererIndex gets set to zero each time a new set of charts
          // gets drawn
          public function getAxisRenderer():AxisRenderer {
                 if (rendererIndex >= rendererArray.length) {
                      var renderer:AxisRenderer = new AxisRenderer();
                      rendererArray.addItem(renderer);
                      rendererIndex++;
                      return renderer;
                 var rend:AxisRenderer = rendererArray.getItemAt(rendererIndex) as AxisRenderer;
                 rendererIndex++;
                 return rend;
          // I have almost identical methods used for memory management for the genericChart, hAxis, vAxis, etc.
          public function getCartesianChart():CartesianChart { // code not shown }
          public function getDateTimeAxis():DateTimeAxis { // code not shown }
          public function getLinearAxis():LinearAxis { // code not shown }
          • 2. Re: Null reference error in axis renderer when redrawing chart
            support & learning
            May i know the solution to overcome the above issue which is urgent, for first time i am getting the same error and my application gets hang.
