1 Reply Latest reply on Oct 6, 2008 6:25 AM by kglad
    use of the keyboard
      i want to move a graphic on a path (something like a map) by using the arow keys. when the graphic goes to a paricular pont i want a window to open with information in it. this window can be closed by the user. also the user can print the informations if he likes to.
        • 1. Re: use of the keyboard
          to use the arrow keys, check the key class.
          to open a window when the graphic (which you should convert to a movieclip) reaches a certain point, use an if-statement checking its position every time the position changes.
          and to print, check the flash printjob class.
