• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFFEED Error message
New Here ,
Oct 06, 2008 Oct 06, 2008
I get this message:
quote:
Unable to read the feed source file C:\websites\dev\http:\rss.news.yahoo.com\rss\mideast
I am trying to use the cffeed. Everything works fine when I use a static feed. But when I try to loop through my db table that contains the RSS Name and RSS Feed, I get the above error message. "C:\websites\dev\" is the web server path. What is causing this to happen? When I manually enter the rss feed in the source attribute it works fine.
works..<cffeed action="read" source=" http://rss.news.yahoo.com/rss/mideast " properties="meta" query="items">
won't work <cffeed action="read" source="#RSS.RSSFEED#" properties="meta" query="items">
TOPICS
Advanced techniques
Views
760
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
dump out your #RSS.RSSFEED# variable and see what it contains. compare
it to what you think it contains/what it should contain and do something
about the differences.
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
Votes
Translate
Translate
Report
Report
New Here ,
Azadi, That was the first thing I did. The cfdump shows exactly what it should be showing.
Votes
Translate
Translate
Report
Report
LEGEND ,
well, if i do this:
<cfset RSS = {}>
<cfset RSS.RSSFEED = " http://rss.news.yahoo.com/rss/mideast">
query="items">
it works fine. that tells me that YOUR RSS.RSSFEED variable does NOT
evaluate to " http://rss.news.yahoo.com/rss/mideast".
Azadi Saryev
Sabai-dee.com
Votes
Translate
Translate
Report
Report
New Here ,
Yes, like I said that works for me too, but when I query the DB for the URL, thats where it doesn't seem to be working. Even though I can output #RSS.RSSFeed# and it shows the correct url. This makes me think somethings wrong with the CFFEED or something with the string coming from the DB. Since the static cffeed works, it must be the way the variable is coming from the DB... but when I dump the variable from the query, I get the actually rss feed that I need.
Here is the page url [L=link Removed
Votes
Translate
Translate
Report
Report
LEGEND ,
it's definitely the value in the db is wrong. but you say when you dump
it it shows up correct? is your code doing any string manipulation on
the data returned by the db?
can you do this:
<pre>
<cfoutput>#RSS.RSSFEED#</cfoutput>
</pre>
just before your cffeed call and post the result here?
Azadi Saryev
Sabai-dee.com
Votes
Translate
Translate
Report
Report
New Here ,
If you go to the page you can see the result.
As, like I said before.... the url is in fact the correct url for the feed. but when the cffeed reads the variable...something happens.
Votes
Translate
Translate
Report
Report
LEGEND ,
what page?
is it too hard for you to add
<pre><cfoutput>#RSS.RSSFEED#</cfoutput></pre> to your code and post the
result here? do you really want to solve this one?
as I said before, the data in your db is most likely incorrect.
unless you do some manipulation on the data returned from the db before
you use it in your <cffeed> - then your db result manipulation is at fault.
as simple a thing as having a / in front of the feed url will cause this
error.
Azadi Saryev
Sabai-dee.com
Votes
Translate
Translate
Report
Report
New Here ,
Oct 07, 2008 Oct 07, 2008
I need to figure out what is going wrong. The page is, I also included it and the code in an earlier post.
Votes
Translate
Translate
Report
Report
LEGEND ,
if you had done what i suggested you would have seen the space in front
of your url and wouldn't have had to bother Ray with this. :)
Azadi Saryev
Sabai-dee.com
Votes
Translate
Translate
Report
Report
New Here ,
Oct 08, 2008 Oct 08, 2008
LATEST
I did what you suggested, Actually, if you had read the orginal post you would have known that. Ray didn't even see this error to begin with.
Votes
Translate
Translate
Report
Report
Resources
Documentation
