4 Replies Latest reply on Jul 9, 2008 7:37 AM by Chris-Kot
    Using Lists between movies
    Chris-Kot
      I wanted to know if something was possible and if so, some guidance on what to do.
      I have an application (which runs from a network drive and is accessed by multiple people, one at a time) that builds
      a part number from options clicked. Once the part number is generated (radio buttons are clicked and a blank text field stores the part number) I use INM Ipressario (PDF xtra) to fill in a requistion form with the Part number, description and pricing. I have the pricing put in a script in a "brute force" method. I was planning on using the INM Database xtra to store pricing in a database, but the xtra does not work over a network. My questions are: Is there a way to create a list to store pricing outside of the movie that requires it? And, can I have another Director application/movie/exe that creates the list. Pricing chages and I don't want to have to update the program every time pricing changes. Also I would like other people to be able to input pricing/change pricing from another director .exe who do not know how to use Director and have my pricing associated with the part number always be up to date. Thanks for any help or advice.
        • 1. Re: Using Lists between movies
          Level 7
          There are loads of ways to write text to external files. There is the
          built in getPref() and setPref() methods which will store the
          preferences on the local machine... that is probably not what you want
          since you will want the preferences shared among a bunch of networked users.
          So, there is the fileIO xtra which comes with Director. You can look it
          up in the help file for syntax and usage. That will let you store
          whatever text you want to a file, and you can store that file anywhere
          that the computer has write access (so if the users have write access to
          a network share, you can put the file there).
          There are other xtras that can do the same thing, some are easier to use
          than the others. propSave and vList can save native Director lists to
          files without turning them into text first, so they are much faster.
          • 2. Re: Using Lists between movies
            Level 7
            "I was planning on using the INM Database xtra to store pricing in a
            database, but the xtra does not work over a network. "
            Are you sure about this? I haven't ever used the INM Xtra, but I have
            used the free SQLite database xtra in a similar fashion. If you can
            create a mapped drive to the shared network folder, it should appear to
            the xtra as just another local disk, and you should be able to read or
            write any files (assuming the user has permissions) including updating a
            database file.
            Another possibility would be to build a client/server application using
            the old MUS xtra. Your server application would have to reside on some
            computer on the LAN, and it would locally access what ever database you
            were using. Your users would run a client application that could connect
            to the server over the LAN or even the internet if you wanted. The MUS
            xtra would allow you to send data back and forth, such as users
            requesting pricing information, adding some new product, etc.
            This is not a trivial task, but it would allow you to have more control
            over how the database would be modified. Remember, just because users
            access the same Director movie from a network drive, it is really no
            different from each one having a copy of the movie on their local hard
            drive. In fact they really do have a temporary copy of the movie (in RAM
            or a cache). So what you get is multiple users each modifying the
            database simultaneously via individual instances of a director movie,
            without the director movies even being aware of each other.
            There are other limitations, such as a limit of 16 simultaneous users.
            Another limitation requires modifying the router configuration if any of
            the users are not on the same LAN as the server. I've experimented with
            the MUS xtra and I am familiar with most of the pitfalls, so I could
            offer you some more details if you really were interested in this route.
            These solutions are require only Director lingo programming. If you
            search the google groups archive you will find information about
            resolving the issue using server side scripting languages.
            • 3. Re: Using Lists between movies
              Level 7
              As well as the other suggestions, the Valentina Xtra might be worth a
              look. They also have a database server that sounds like it would suit
              your needs and the xtra can communicate with this - all it needs is an
              IP, port, etc.
              • 4. Re: Using Lists between movies
                Chris-Kot Level 1
                Thank you for all of your input. It helps running this by others and getting different thoughts. I will look into what you all have suggested.
                Thanks again
