3 Replies Latest reply on Oct 23, 2008 1:48 PM by kglad
    complicated drap and drop
    Dfrazee Level 1
      Hello, I am trying to do something with my drag and drop game that is too complicated for me to find on any tutorial.
      I am trying to set it up so that when the item is being dragged and it is over the correct drop area, the item blinks (which I have animated on the 2nd frame and beyond in each item). The problem is, I can't seem to run a hitTest while the item is being dragged, or onPress of the item. I have even tried to set an interval so that my indicator function runs every 50 milliseconds. I have included the sample script below, if anyone could help me it would be greatly appreciated.
      //------//var intervalId:Number
      function indicator(item,labels){
      if(eval(item).target_mc.hitTest(eval(labels).target_mc)){
      eval(item).gotoAndStop(2);
      //-------//intervalId = setInterval(indicator, 50);
      function labelsTest(item,labels){
      eval(item).stopDrag();
      eval(labels).gotoAndStop(2);
      eval(item).enabled=false;
      eval(item)._visible=false;
      counter++;
      if (counter==7){gotoAndStop("continue");
      item1_mc.onPress = function () {
      item1_mc.startDrag();
      item1_mc.swapDepths(this.getNextHighestDepth());
      indicator("item1_mc","label1_mc");
      item1_mc.onRelease = function () {
      labelsTest("item1_mc","label1_mc");
        • 1. Re: complicated drap and drop
          indicator() needs to repeatedly execute after your onPress handler executes. eg, start an onEnterFrame or setInterval() loop from your onPress handler and clear that loop in your onRelease.
          p.s. there's no need to convert those movieclip names to strings and then re-convert them to movieclips. just pass the movieclips to indicator().
          • 2. Re: complicated drap and drop
            Dfrazee Level 1
            Allright, the reason why I am setting them as strings is because I have a lot more movie clip(draggable items) than I included the code for. I have tried a couple of your suggestions and it doesn't seem like the hitTest is operating at all while the mouse is pressed. here are a couple things that I have tried
            eval(item).gotoAndPlay(2);
            eval(item)._x=eval(labels)._x;
            eval(item)._y=eval(labels)._y;
            clearinterval(intervalId);
            counter++;
            I have also tried to set my interval like this
            intervalId = setInterval(indicator("item1_mc","label1_mc"), 50);
            Thanks a bunch for your feedback on this,
            • 3. Re: complicated drap and drop
