Expand my Community achievements bar.
SOLVED
AEM 6.1 | Escape special chars in Sightly
Avatar
Level 4
Hi All,
I want to escape chars like "<", ">" and "/" in sightly. I have this piece of code:
${"{1}{0}{2}{1}{3}{0}{2}" @ format=[properties.test,'<','>','/']} - but its rendering in HTML as &lt;test-data&gt;&lt;/contact-us&gt;
I checked this  https://docs.adobe.com/docs/en/aem/6-0/develop/sightly/expression-language.html  but could not solve the issue.
So How do I achieve this in Sightly? I bascially need a html tag - <test></test> , where "test" will be from dialog.
Thanks!!
1 Accepted Solution
Avatar
Correct answer by
Administrator
Hi
You can refer to Sightly Specification:- https://github.com/Adobe-Marketing-Cloud/sightly-spec/blob/master/SPECIFICATION.md (Search Escape)
Like in JavaScript, strings quotes can be escaped by prefixing a backslash to the quote (\') or double-quote (\").
Single character escape sequences: \t \b \n \r \f \' \" \\
Unicode escape sequences: \u followed by 4 hexadecimal digits (e.g.: \u0022 for ", \u0027 for ', \u003c for <, or \u003e for >
I hope this will help.
Thanks and Regards
Kautuk Sahni
Kautuk Sahni
View solution in original post
Avatar
Correct answer by
Administrator
Hi
Thanks and Regards
Kautuk Sahni
Kautuk Sahni
Avatar
Level 4
HI Kautak,
Thanks For your reply, I went through the document it was helpful indeed, but I am not able to quite achieve what i wanted to, Can you please tell me the syntax for the above mentioned requirement.
Thanks!!
Avatar
Administrator
CQ_learner wrote...
HI Kautak,
Thanks!!
Use:-   ${ '{0} {1} {2} {3}' @ format=['\u003e','\u003C', '\u002F', '\u005C']}
This will print :-        > < / \
PS:- To get Hex value of any character, you can use "http://www.endmemo.com/unicode/unicodeconverter.php". Enter a character in Unicode Character and look for result in Escaped Unicode. Also if Escaped Unicode is coming out to be \u3e use it as \u003e.
I hope this will work for you.
Thanks and Regards
Kautuk Sahni
Kautuk Sahni
Avatar
Level 4
Hi Kautuk,
Thanks for the reply, I am able to create the String with <text></text>,But the issue is I need to convert this into a html tag and not as a text or string. It should appear in the DOM and not in the page.
Thanks!
Avatar
Administrator
CQ_learner wrote...
Hi Kautuk,
Thanks!
Hi
I am not sure what exactly is your Question.
Just go to Component.html and create a Tag that your would want to create.
Like :-
See the DOM :-
If you want to create a tag using some string generated from sightly, then you can create a JavaScript with the function accepting a string (sightly string) and this JS function can create a tag for you.
Link:- https://docs.adobe.com/docs/en/aem/6-0/develop/sightly/use-api-in-javascript.html
Reference Read:- http://blogs.adobe.com/experiencedelivers/experience-management/4-ways-try-javascript-use-api-sightl...
Thanks and Regards
Kautuk Sahni
Kautuk Sahni
Avatar
Level 4
HI Kautak,
Yes this excatly is my issue, i need properties.test value inside "<></>", suppose properties.test = "myTest", I want a html tag like this -
<myTest></myTest>, Is this possible through sightly in any way?
Avatar
Administrator
CQ_learner wrote...
HI Kautak,
Then your problem reduces to "Creating a Custom Tags".
Please refer to this article:- http://www.html5rocks.com/en/tutorials/webcomponents/customelements/
Instantiating elements
The document.registerElement() method is used to create a custom HTML element. This should be passed as the name of your custom element along with an (optional) object that defines the API.
Declare them:
<x-foo></x-foo>
Create DOM in JS:
var xFoo = document.createElement('x-foo');
xFoo.addEventListener('click', function(e) {
  alert('Thanks!');
Use the new operator:
var xFoo = new XFoo();
document.body.appendChild(xFoo);
Another Reference Article :- http://blog.teamtreehouse.com/create-custom-html-elements-2
Now, you can call a JS function from Sightly with arguments (Link) which will create custom element/tag (Link) for you.
Thanks and Regards
Kautuk Sahni
Kautuk Sahni
