5 Replies Latest reply on Feb 16, 2009 9:59 AM by gindala
    Flex doesnt compile after error
    Matt Gifford Level 1
      Hi all.
      I've had this problem on and off for a few weeks, but today it's been ridiculous.
      I'm using build 3.01.205647 of Flex Builder.
      When I try to compile an AIR app locally to test, it's throwing an error (#2030, which I'm fixing)
      However, the trouble I'm having is that whenever I fix the issue and try to recompile, nothing happens. The workspace is refreshed by the builder, but nothing else.
      I also have almost constant trouble with using the Flex debugger. It never wants to run, and says:
      quote:
      Process terminated without establishing connection to debugger.
      Command: "C:\Program Files\Adobe\Flex Builder 3\sdks\3.1.0\bin\adl.exe"
      C:\Inetpub\wwwroot\BTX-debug\BTX_4-app.xml C:\Inetpub\wwwroot\BTX-debug
      Output from command: invocation forwarded to primary instance
      Please can someone help me? I'v restarted my pc five times today, and have to do so each time Flex Builder freezes up.
      Many thanks,
      Matt
        • 1. Re: Flex doesnt compile after error
          Gregory Lafrance Level 6
          With AIR apps, if you have an instance of the app running. not in debug mode, then it seems like you can't debug the app till you close that open instance. Maybe that's it.
          • 2. Re: Flex doesnt compile after error
            Hi Greg
            thanks for your quick reply
            I haven't got any other instances of the application running at all, and the issues still there. I was able to just get debug working again, but now it's stopped compiling once more, and so it's time for PC restart #8 of the day.
            Please can someone help?
            Many thanks
            • 3. Re: Flex doesnt compile after error
              Level 7
              "Mattg2379" <webforumsuser@macromedia.com> wrote in message
              news:gdnfc7$cep$1@forums.macromedia.com...
              > Hi all.
              > ridiculous.
              > to
              > nothing else.
              > to
              Did you try Project>clean?
              It seems to me AIR projects have more problems getting "dirty" than others.
              You may also find this link helpful
              http://mayur-bais.blogspot.com/2007/09/airs-adlexe.html
              • 4. Re: Flex doesnt compile after error
                I wonder if an AIR related process is still running, though not visible. Is this Windows? Is there an adl.exe in TaskManager?
                • 5. Re: Flex doesnt compile after error
                  gindala
                  I found that killing the ADL process solved the problem for me.
