1 Reply Latest reply on Oct 17, 2008 6:27 PM by Walter Elias
    Can Flash CS4 be installed and run on the same computer as Flash CS3?
    adamll Level 1
      Will I be able to install Flash CS4 and keep Flash CS3? Can I run both at the same time on the same computer?
      I have several older projects that I would like to maintain only in Flash CS3 for various reasons. If I have to set up a separate computer just for developing in CS4, I would like to know ahead of time.
      Thanks in advance.
        • 1. Re: Can Flash CS4 be installed and run on the same computer as Flash CS3?
          Walter Elias Level 2
          You should be able to. CS4 would install to a separate CS4 directory. I currently have a system running CS3 web suite, plus Flash 8 and InDesign CS2! Once in a while, the system gets confused between Flash 8 and CS3 as the default Flash to open when clicking on a FLA file in Windows Explorer. But other than that, there are no other issues.
          I plan to get CS4 and still keep Flash 8 and CS3, just because I work with people around the world who don't care to upgrade.
