9 Replies Latest reply on Oct 24, 2008 4:46 AM by MergeThis
    Numbered list (procedure) with graphics
    yenelli Level 1
      My procs have graphics of GUI snippets, using the <OL></OL> (and removing extra pairs). Looks great in RH. In published Help, it SKIPS numbers (giving the unnumbered graphics paragraphs an "unseen" number).
      Item 20 on Peter Grainge's web site doesn't work...yet I've done this successfully in the past,
      Also, procs have Times Roman numbers with Verdana text, but Adobe's RoboHelp for HTML topic titled Bullets Within Numbered Lists Are Incorrect (https://www.substraterecords.com/cfusion/webforums/forum/messageview.cfm?forumid=65&cati d=449&threadid=1391205&enterthread=y#5078043) doesn't help with my CSS, which appears to be derived from definitions set using RH toolbar to create/edit styles; I see no place to designate a style for numbered list.
        • 1. Re: Numbered list (procedure) with graphics
          yenelli Level 1
          I've attached snippet from proc that contains screenshot: numbering is fine in WYSIWYG of RH 5 for HTML, but in published Help, step 3 is numbered with 4, and 3 seems to be skipped.
          • 2. Re: Numbered list (procedure) with graphics
            MergeThis Level 4
            See my response to a similar, recent question.
            The style "P.Numlist" and the class assignment "<li class=kadov-p-CNumlist>" are not compatible. List styles need to be controlled with OL, UL, and LI styles.
            Leon
            • 3. Re: Numbered list (procedure) with graphics
              yenelli Level 1
              Leon (or others)
              Could you please provide some actual samples from a .css file?
              Here's some OL and UL in my .css file, which all topics are using (how would you specify them differently?):
              BulList = Normal+margin-left: 0px; list-style: inside disc; (paragrph has a hanging indent for the disc).
              • 4. Re: Numbered list (procedure) with graphics
                yenelli Level 1
                Leon (or others)
                • 5. Re: Numbered list (procedure) with graphics
                  yenelli Level 1
                  (cont'd)
                  Numlist = Normal + list-style: decimal; OL:'\007b' 'margin-top' 5pt margin-bottom: 5pt; font-family:Verdana, sans-serif; font-size 10 pt;
                  NumListAbc = Normal + list-style: lower-alpha
                  Question = Normal + list-style: inside (url9bgred.gif);
                  Why is OL missing from the NumListAbc, why are numbers in Numlist in Times Roman font, what is '\007b' why is kadov interjecting its own definitions? Why is Question putting a (red) bullet on one line and the text of the question on the next line--only on compiled page, WYSIWYG looks fine. BulList does same thing. (How do you express these in a .css?)
                  • 6. Re: Numbered list (procedure) with graphics
                    MergeThis Level 4
                    Oh, dopey me, and here I thought I had pointed yenelli to a previous response that did have an actual sample from a .css file!
                    Oh, wait, that response does have an actual sample from a .css file. Now, why is yenelli still asking for an actual sample? Hmmmm....
                    Maybe yenelli was too busy to link to that response? And that W3C web site has a sample that you can actually edit and see the changed results on-the-fly!
                    Oh, well...
                    • 7. Re: Numbered list (procedure) with graphics
                      yenelli Level 1
                      Hello Merge This,
                      That's not helpful, though it is sarcastic. I reviewed the examples in the referenced message before I asked for additional help.
                      My .css file, opened in Notepad, is heaps of kadov definitions with explicit warnings not to edit or delete. Do I put your code before or after or into the Kadov definitions?
                      Futher, the lists and procedures in the TrueCode view of my TOPIC files are couched in <OL></OL> and <UL> </UL>.
                      Here's the sample code in the referenced topic:
                      You would be better off assigning the OL and UL styles separately, and adding the font info there, such as here for OL:
                      OL { margin-top: 0px; margin-bottom: 0px; font-family: Verdana, sans-serif; font-size: 10pt;}
                      So, in RoboHelp'w WYSIWYG what style does one assign to numbered paragraphs in a procedure? Just use Normal style and use the RoboHelp formatting buttons (<Create a Numbered List> <Create a Bulleted List>)? I have (alphabetically) numbered substeps, secondary paragraphs that have no numbers, and screenshots in the proc. RH puts numbers on the screenshots. If I used straight HTML, I'd throw in a couple of <br> and that would solve the issue. I'm tyring to use the RH UI to apply styles and I am not able to decipher how to apply your OL "code sample" using the Formatting Toolbar in RH. Are you suggesting one doesn't use styles (NumList)?
                      How does your OL code sample relate to the NumList and NumListAbc styles in my question?
                      • 8. Re: Numbered list (procedure) with graphics
                        yenelli Level 1
                        and How does the W3C sample relate to Robohelp Formatting toolbar?
                        • 9. Re: Numbered list (procedure) with graphics
                          MergeThis Level 4
                          "Are you suggesting one doesn't use styles (NumList)?" Yes, I am.
                          You're still thinking in Word formatting, as far as "styles" go. I've found that best practice is to use the basic OL/UL/LI HTML elements for formatting, and completely forget numlist/bulletlist styles. (An important side effect of this method is that the lists will appear exactly the same when/if you generate Printed Doc, which isn't usually the case when using "styles.")
                          As to the W3C site I provided, click CSS List on the left, then click "The different list-item markers in ordered lists." Another window will open with two panes, and a button labeled "Edit the text and click me." Try any combination of things and get instant feedback of the results.
                          "Do I put your code before or after or into the Kadov definitions?" Neither; these CSS elements will be used instead of your current "styles." For example, the entire "P.Numlist" declaration would no longer be used, or needed. Once you've added the elements to CSS, RH might add some DO NOT DELETE stuff; ignore it and leave it alone. (Some RH code is added simply to render your formatting in the WYSIWYG editor, while other code actually controls how things get generated in your output.)
                          Leon
