2 Replies Latest reply on Dec 8, 2016 12:46 PM by tacia.c
    How does Marketing Cloud ID Service & Analytics Visitor ID function in Data Feed
    tacia.c Level 1
      Hello!
      Testing out a new implementation to Marketing Cloud ID service. Looking at the Adobe Analytics data feed, the visid_high & visid_low columns now show '0'. Testing on the page there is an mid and an aid. With MCID active, does the visid_high & visid_low column no longer populate? We aren't currently pulling in post_visid_type so it's difficult to pinpoint the exact reason.
      Thanks!
      Tacia
        • 1. Re: How does Marketing Cloud ID Service & Analytics Visitor ID function in Data Feed
          Jantzen.Belliston Adobe Employee
          Hi Tacia,
          The visid_high & visid_low columns are based off the 'aid' value. Deploying the MCID service can change what you're seeing in data feeds, but it doesn't control that column. Below are a few scenarios that you might see:
          Scenario 1
          MCID service deployed with grace period activated (New or Returning Visitors)
          Result:  You're hit would have a s_vi cookie and therefore an 'aid' value. This means you should see values in the visid_high & visid_low columns
          Scenario 2
          MCID service deployed with no grace period activated (New Visitor)
          Result:  You're hit would only contain a 'mid'. This means you should not see values in the visid_high & visid_low columns
          Scenario 3
          MCID service deployed with no grace period activated (Returning Visitor)
          Result:  You're hit should contain both a 'aid' and 'mid'. This means you should see values in the visid_high & visid_low columns
          I know in your post you indicated the page had both a 'mid' and 'aid". Have you verified that those hits have an 'aid' do not have a visid_high & visid_low?
          Jantzen
          • 2. Re: How does Marketing Cloud ID Service & Analytics Visitor ID function in Data Feed
            tacia.c Level 1
            That was exactly what I needed to know. Thanks Jantzen!
            -Tacia
