1 Reply Latest reply on Oct 15, 2015 7:28 PM by shekhardhiman
    How to set up a clustered configuration of Insight Server?
    book_find
      There is tow machines, one as FSU, another as DPU
      I want to set up a clustered configuration of Insight Server, and have performed the following
      general steps:
      1.In the master Insight Server(FSU), add the processing server ip to  Access Control Groups and
      add Master Server Common Name to Cluster.cfg
      2.Add the processing Insight Servers'common names and addresses to the address file (in Master
      Server)
      3.Add all of the Insight Servers to the Cluster Servers group in the Access Control.cfg file(in
      Master Server)
      4.Update the Synchronize.cfg file in the “Components for Processing Servers” directory to
      point to the master Insight Server(in Master Server)
      5.Delete the original Components directory on the processing Insight Server and Rename the
      “Components for Processing Servers” directory to “Components.”,  and Modify the
      Synchronize.cfg in the Components directory to point to the master Insight Server
      6.In the profile.cfg file, specify the processing servers that process the data for the
      profile(on Master Server)
      I had performed all steps of above, but insight get an error:
      500 Address not found: xxxx
      (xxx is the dpu server common name)
      To set up a clustered configuration of Insight Server, what can I do?
      thanks!
      • 0. Re: How to set up a clustered configuration of Insight Server?
        shekhardhiman Adobe Employee
        Hi There,
        Thank you for reaching out to Adobe Community.
        You might want to look at the server installation guide below in order to understand the process more:
        https://marketing.adobe.com/resources/help/en_US/insight/svrprod/
        https://marketing.adobe.com/resources/help/en_US/insight/svrprod/c_ins_svr_clstrs.html
        Thanks!
