1 Reply Latest reply on Oct 30, 2008 5:31 PM by Mayra999
    log to file from installed air application
    Mayra999 Level 1
      I have an application I've developed using flex builder, which uses the flex logging library. When I run it from the debugger in flex builder I get useful log information in the flashlog.txt file. Eventually my application is turned into an air file which is installed on the target machine. Is there any way to get that log output when I run the air application? Some output appears in the flashlog.txt, but not the same output as I see when running it with the flex builder.
