0 Replies Latest reply on Oct 23, 2008 3:03 PM by sreedharvaddi
    Problem sending the parameters to webservice
    sreedharvaddi
      Hi all,
      i am trying to call a "peoplesoft" webservice from flex. The following are the files automatically generated by peoplesoft integration broker.
      <wsdl:definitions name="CI_DEPT_CF.1" targetNamespace=" http://xmlns.oracle.com/Enterprise/FSCM/service/CI_DEPT_CF.1">
      <wsp:UsagePolicy wsdl:Required="true"/>
      <plnk:partnerLinkType name="CI_DEPT_CF_PartnerLinkType">
      <plnk:role name="CI_DEPT_CF_Provider">
      <plnk:portType name="tns:CI_DEPT_CF_PortType"/>
      </plnk:role>
      </plnk:partnerLinkType>
      <wsdl:types>
      <xsd:schema elementFormDefault="qualified">
      <xsd:import namespace=" http://xmlns.oracle.com/Enterprise/FSCM/schema/M606637.V1" schemaLocation="M606637.V1.xsd"/>
      <xsd:import namespace=" http://xmlns.oracle.com/Enterprise/FSCM/schema/M979725.V1" schemaLocation="M979725.V1.xsd"/>
      <xsd:import namespace=" http://xmlns.oracle.com/Enterprise/FSCM/schema/M505071.V1" schemaLocation="M505071.V1.xsd"/>
      </xsd:schema>
      </wsdl:types>
      <wsdl:message name="M606637.V1">
      <wsdl:documentation>M606637</wsdl:documentation>
      <wsdl:part element="M606637.V1:Get__CompIntfc__DEPT_CF" name="parameter"/>
      </wsdl:message>
      <wsdl:message name="M979725.V1">
      <wsdl:documentation>M979725</wsdl:documentation>
      <wsdl:part element="M979725.V1:Get__CompIntfc__DEPT_CFResponse" name="parameter"/>
      </wsdl:message>
      <wsdl:message name="M505071.V1">
      <wsdl:documentation>M505071</wsdl:documentation>
      <wsdl:part element="M505071.V1:error" name="parameter"/>
      </wsdl:message>
      <wsdl:portType name="CI_DEPT_CF_PortType">
      <wsdl:operation name="CI_DEPT_CF_G">
      <wsdl:documentation>CI_DEPT_CF_G</wsdl:documentation>
      <wsdl:input message="tns:M606637.V1" name="M606637.V1"/>
      <wsdl:output message="tns:M979725.V1" name="M979725.V1"/>
      <wsdl:fault message="tns:M505071.V1" name="M505071.V1"/>
      </wsdl:operation>
      </wsdl:portType>
      <wsdl:binding name="CI_DEPT_CF_Binding" type="tns:CI_DEPT_CF_PortType">
      <soap:binding style="document" transport=" http://schemas.xmlsoap.org/soap/http"/>
      <soap:operation soapAction="CI_DEPT_CF_G.V1" style="document"/>
      <wsp:Policy wsu:Id="UsernameTokenSecurityPolicyPasswordOptional">
      <wsp:ExactlyOne>
      <wsp:All>
      <wsse:SecurityToken wsp:Usage="wsp:Required">
      <wsse:TokenType>wsse:UserNameToken</wsse:TokenType>
      <Claims>
      <SubjectName MatchType="wsse:Exact"/>
      <UsePassword wsp:Usage="wsp:Optional"/>
      </Claims>
      </wsse:SecurityToken>
      </wsp:All>
      </wsp:ExactlyOne>
      </wsp:Policy>
      <wsdl:input name="M606637.V1">
      <soap:body encodingStyle=" http://schemas.xmlsoap.org/soap/encoding/" use="literal"/>
      </wsdl:input>
      <wsdl:output name="M979725.V1">
      </wsdl:output>
      <wsdl:fault name="M505071.V1">
      <soap:fault encodingStyle=" http://schemas.xmlsoap.org/soap/encoding/" name="M505071.V1" use="literal"/>
      </wsdl:fault>
      </wsdl:operation>
      </wsdl:binding>
      <wsdl:service name="CI_DEPT_CF">
      <wsdl:documentation>CI_DEPT_CF</wsdl:documentation>
      <wsdl:port binding="tns:CI_DEPT_CF_Binding" name="CI_DEPT_CF_Port">
      <soap:address location=" http://jupiter.smarterp.com:9051/PSIGW/PeopleSoftServiceListeningConnector"/>
      </wsdl:port>
      </wsdl:service>
      </wsdl:definitions>
      <xsd:schema elementFormDefault="qualified" targetNamespace=" http://xmlns.oracle.com/Enterprise/FSCM/schema/M606637.V1">
      <xsd:element name="Get__CompIntfc__DEPT_CF" type="Get__CompIntfc__DEPT_CFTypeShape"/>
      <xsd:complexType name="Get__CompIntfc__DEPT_CFTypeShape">
      <xsd:sequence>
      <xsd:element name="SETID" type="SETIDTypeShape"/>
      <xsd:element name="DEPTID" type="DEPTIDTypeShape"/>
      </xsd:sequence>
      </xsd:complexType>
      <xsd:complexType name="SETIDTypeShape">
      <xsd:simpleContent>
      <xsd:extension base="SETIDTypeDef"/>
      </xsd:simpleContent>
      </xsd:complexType>
      <xsd:complexType name="DEPTIDTypeShape">
      <xsd:simpleContent>
      <xsd:extension base="DEPTIDTypeDef"/>
      </xsd:complexType>
      <xsd:simpleType name="SETIDTypeDef">
      <xsd:restriction base="xsd:string">
      <xsd:maxLength value="5"/>
      <xsd:whiteSpace value="preserve"/>
      </xsd:restriction>
      </xsd:simpleType>
      <xsd:simpleType name="DEPTIDTypeDef">
      <xsd:maxLength value="10"/>
      </xsd:restriction>
      </xsd:simpleType>
      </xsd:schema>
      can you suggest me how to call this web service .
