2 Replies Latest reply on Oct 27, 2008 2:46 AM by jdldn
    make slice behave like normal object so when selected second and aligned to an object, the object wont move.
    jdldn Level 1
      When aligning 2 objects using the align panel, the object I select second is the one that is moved and the object selected first does not move.
      This however is not the case when selecting an object and a slice. I need my slice to be centered around an object so when I export the image and center it in a div it lines up correctly. Is there a way of doing this?
      thanks
