1 Reply Latest reply on Oct 23, 2008 12:17 PM by Peter Lorent
    Any way to set separate compile setting for applications in same project
    rjschloss
      I am trying to implement some automation functionality into a couple applications which requires using the include-libraries param in the compiler arguments line. Because this action affects all the applications in the project the other applications are affected by these changes. What I would like to do is create an application to run automation tests and an application which is the realtime application. Does anyone know if there is a way to create customized application compiler settings in FlexBuilder?
